Old May 17, 2001, 08:47 AM
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
What is the fastest motor for a ZAGI!
So which one is it???
funflyer is offline Find More Posts by funflyer
Old May 17, 2001, 09:24 AM
Adam in Toronto's Avatar
Toronto, Ontario, Canada
Joined Mar 2001
I'm using an Astro 020 in my Zagi. When using a 5.5/5.5 cam speed prop I get amazing vertical performance, but my flight times are only about 1 1/2 minutes. I switched to a 4.7/4.7 cam, and I have great performance and about 3-4 minute flight times
[This message has been edited by Adam in Toronto (edited 05-17-2001).]
Adam in Toronto is offline Find More Posts by Adam in Toronto
Old May 17, 2001, 09:27 AM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
I understand someone has strapped an Aerotech E15 on a Zagi. Should be really fast, but burn time is only a little over 2 seconds .
Sorry, I couldn't resist.
- Roger
gnofliwr is online now Find More Posts by gnofliwr
Old May 17, 2001, 09:33 AM
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
... the Zagi and the prop spun in opposite directions at the same RPM?
Bill Glover is online now Find More Posts by Bill Glover
Old May 17, 2001, 10:01 AM
kansas city
Joined Jan 2001
yeah and my simple promax 4014 14 turn with a fourbladed prop kicked its ass all over. to bad i get longer runs with consistant torque than you astro .020 no matter how hard or tight i pull loops does inverted loops and faster top end its a damn shame i only spent 64.00 hell i think im gonna cry !
darn i didnt spend 200.00 your combo must be
better you spent more money right :-)
paul dare is offline Find More Posts by paul dare
Old May 17, 2001, 11:11 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
For a cheap but VERY fast combination the tried and true Multiplex 450 Turbo and 8x800ARs sounds like the way to GO.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old May 17, 2001, 02:57 PM
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
The combo that Mark described is great with an Aeronaut 6.5x4 prop. It howls.
DaJudge is offline Find More Posts by DaJudge
Old May 17, 2001, 05:09 PM
Joined Apr 2001
I run an Astro 020 in my 400X. I tried a few props and am very happy with the CAM 4.7 x 4.7. I get about 14 minutes at full throttle with great speed. 17 minutes with throttle management. I have also logged 40 minute flights with thermals - could have gone more - but wasn't going to risk the battery going flat.
It is a bit expensive at $200 - but keep in mind that the speed controller comes with it. I priced others and found that you come close to the same price after you buy everything.
mpj220 is offline Find More Posts by mpj220
Old May 17, 2001, 05:31 PM
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
One person say the astro gets 3 and a half mins..And one says they get 17 mins...SO whos telling the truth????
Old May 17, 2001, 05:45 PM
Joined Mar 2001
He has longer flight times because he's using larger batteries(1700 mah I think). His plane lasts much longer, but i'd bet mine goes faster because its lighter
Old May 17, 2001, 07:32 PM
Angola, IN USA
Joined Mar 2000
I have a regular Zagi with RS 1600 Nimhx8, 500ARx8 and 800 ARx8. I flew it with the regular s400 motor first. OK. Then I saw the astro 020. What a difference! 1.5 minutes 500 AR and they are HOT. 5" 1600Nimh and they are so hot they melt the glue on the velcro attachments. I have not tried this with the 800 AR. I am a little worried about the amp draw, as I am already close to 20 or so.
I then bought for comparison a Permax 450 turbo and 6.5x4 prop with my 800 AR cells. I would say performance is at least equal to the Astro 020 with 1600 Nimh cells. I have yet to compare the 800 AR cells. I was using a cox 5x3.5 3 blade pusher prop with the astro, so it's hard to make an apples/apples comparison. I would have to send it back to astroflight for retiming if I want to use the 6.5x4. As I am so happy with the Permax 450 I will probably keep the astro for a fast s400 pylon if I ever get up the nerve, or if I don't sell it first.
The permax setup: 8x800AR Jeti 35 Permax 450 turbo and 6.5x4 cam prop=about $130 (3" full throttle or so...)
The astro setup: 1600 Nimh RS x8 Astro 020 and controller, cox prop = $226 or so. (5"+full throttle)
My zagi is a bit heavy, too, for "structural integrity" (It was my trainer...)
DPW
dwatkins is offline Find More Posts by dwatkins
Old May 19, 2001, 05:50 AM
Northern New Mexico
Joined May 2001
My friends use a Norvel .061 with a tornado 6x4 prop. and a 4 oz. gas tank. That setup CRANKS OUT THE POWER for over 10 minutes.
fregon45 is offline Find More Posts by fregon45
Old May 19, 2001, 06:53 AM
Joined Apr 2001
Adam -
You may want to try the 1700 packs - it will turn the motor faster. I had a 400 with this motor running 8 x 600AE batteries and the current draw would immediately drop the voltage of the battery causing it to spin slower.
I built a new 400X using no fiber tape and no covering tape. I installed 2 3/16th's carbon fiber rods and covered with econocote. This saved tons of weight and it is not much heavier than the stock 400. I run 1700 packs and get 14 minutes at full out. I made the battery bay longer in the front as it wouldn't balance out with the size provided. And it still fits the 600AE's and will balance with them all the way forward (good thing - I have 8 of those packs).
I decided that since I had such a weight savings that I added blinking landing lights for night flight. Neon will be coming soon.
Old May 19, 2001, 01:45 PM
Joined Mar 2001
I also covered my Zagi with film and have also placed a carbon fiber rod too. I have decided to go with 10 500 mah batterries. It will not solve my duration problem, but my Zagi would outperform almost every other one.
Old May 19, 2001, 01:51 PM
memphis, tn
Joined May 2001
What motor do you use 10 cells on Adam? What is your duration?
Also, is a speed 450 stronger than a speed 480?
And, what duration do you get, Andy, with a speed 450 and 8 800AR cells? Are these the same 800AR's they sell at tower hobbies for rx packs and individual "fast-charge" cells?
Austin Carpenter
austin9000 is offline Find More Posts by austin9000
What's the best brushless motor for a Zagi/Razor H-tail Foamies (Kits) 7 Feb 20, 2003 09:26 AM
What is a good replacement motor for Zagi 400X? Jon h Foamies (Kits) 22 Oct 22, 2001 12:02 PM
Replacement motor for a Zagi...need more oomph Woody Electric Plane Talk 9 Jul 16, 2001 08:06 PM
What is the best charger for zagi batteries? funflyer Power Systems 3 Jun 05, 2001 11:24 AM
What is the best charger for zagi batteries? funflyer Foamies (Kits) 2 Jun 04, 2001 09:07 PM
