Old Dec 08, 2014, 10:35 AM
United States, CA, Auburn
Joined Jan 2009
600mW AV Transmitter DALRX TX600 FPV 5.8G 32CH
any body has or seen this vtx ?..looks promising
pls comment what you guys think..
http://www.banggood.com/DALRC-DIY-5_...-p-958536.html
pinoydad is offline Find More Posts by pinoydad
Old Dec 12, 2014, 01:05 PM
Joined Oct 2014
I'm interested in acquiring it if someone post positive feedback.
Description at another chinese online store:
600mW full power, no frequency drift, it can work reliably even without heat sink, long distance.
* For reference, when use 14db plate type antenna for receiver, our customer reached 5-6Km without image break off during test.
At goodluckbuy it's a little bit more expensive:
http://www.goodluckbuy.com/dalrc-diy...?&currency=usd 47.4$
lilopiglet is offline Find More Posts by lilopiglet
Old Dec 13, 2014, 06:31 AM
Joined Oct 2014
Wow! measured 649mW
Looks like that the version of this transmitter that is not DIY has been tested with immersionRC power meter and seems truthful:
http://www.banggood.com/DAL-TX600-FP...-p-958539.html 41.69$ free shipping
Old Dec 14, 2014, 02:22 AM
Joined Jan 2009
did you do this test your self?
Old Dec 14, 2014, 02:15 PM
Joined Oct 2014
No, sorry, It's just a picture at the Banggood product page
Old Dec 19, 2014, 12:32 PM
Joined Jan 2009
any one ou there have this ?
Old Dec 19, 2014, 06:18 PM
Joined Oct 2014
Surveilzone sells the same 600mw transmitter:
http://www.surveilzone.com/5.8g-32ch...-tx-fpv-ws1195 46$ free shipping
It says XAT brand but I think that it's the same hardware as DALRC
Old Dec 20, 2014, 04:46 AM
ukbren's Avatar
United Kingdom, Derbyshire
Joined Aug 2011
I've got one (DAL TX600) on order but don't have any test equipment so won't be able to give any scientific input. Note that the SZ transmitter linked above includes a mushroom antenna. The base price $41 tx at BG doesn't (similar price $46 or so for one including an antenna).
ukbren is online now Find More Posts by ukbren
Old Dec 21, 2014, 01:53 AM
Joined Jan 2009
will you pls do a review when you get it ..range specially ..just tired of spending 100 bucks or so on 600 mw ..that antenna connector break off easy got 3 of those here
Old Dec 21, 2014, 03:34 AM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
I got the BG version on the way (maybe next week, I will got it) and the immersionRC powermeter.... So I will confirm (or not) all promised measurements
SeByDocKy is online now Find More Posts by SeByDocKy
Old Dec 22, 2014, 12:42 AM
United States, FL, Pinellas Park
Joined Feb 2014
I sell these and will not ever sell anything else. It's the best bang for the buck!!!
The input is the same as the output, so be careful powering cameras. But for a 3s configuration, it's plug and play via a servo lead to a board camera.
I fly this in parks through trees and they work great!!!
Boozshey is offline Find More Posts by Boozshey
Old Dec 22, 2014, 04:19 AM
SeByDocKy's Avatar
Joined Dec 2012
So it's not outputting +5V ? but it's a direct derivation if the input ?
Good to know ...
Old Dec 22, 2014, 06:50 AM
Joined Oct 2014
Would be great to watch a video flying through trees so we can compare with other transmitters, do you happen to have any dvr footage?. What antennas are you using with it?
thanks
Turbini is offline Find More Posts by Turbini
Old Dec 22, 2014, 03:09 PM
United Kingdom, England, Barnsley
Joined Nov 2014
Good to know ...
The banggood readymade version (http://www.banggood.com/DAL-TX600-FP...-p-958539.html) should ouput 5v according to the specs:
Input Voltage: 7-26V
Output Voltage: 5V(for Gopro or 5V camera power supply)
Mine arrived at the weekend but haven't tried it out yet. I'll be testing the output voltage before I connect it to my camera though, just to be on the safe side.
CrappoMan is offline Find More Posts by CrappoMan
Old Dec 22, 2014, 05:51 PM
Joined Feb 2014
They may have a revision. If that is the case everyone needs to be really careful. Cause I can assure you that there are some out there that put out the same voltage that is coming in. The 5v signal would be coming off the same power source as the vtx then. Presently the way they are wired is the power output is connected directly to the power input.
So again, double check because you might not have the 5v one.
Sold Blown ImmersionRc 5.8 Ghz, 600 mw Vtx dsheikh573 FPV Equipment (FS/W) 7 Apr 29, 2014 12:00 PM
For Sale Immersion RC uno5800 v2 and 600 mw vtx FS xxkiloxx FPV Equipment (FS/W) 19 Feb 16, 2014 01:20 PM
Sold ImmersionRC 5800 Duo / 600 Mw Vtx / IBCrazy CL SKW / 5 turn helical 747Pilot FPV Equipment (FS/W) 8 Dec 29, 2013 04:18 PM
Wanted 1258/1280 vtx 300 to 600 mw faber FPV Equipment (FS/W) 0 Jun 05, 2013 06:29 PM
Wanted 600 mw vtx Ljryeaiii FPV Equipment (FS/W) 6 Sep 30, 2012 10:42 AM
