Old Mar 23, 2012, 02:44 PM
United Kingdom, England, Portsmouth
Joined Jan 2009
Help!
900g glider motor/prop recomendations?
can some one please recomend me a good motor/prop setup for my 1.6m kfm9 glider i have built, i know its a bit porky but hey its a scratch build.
all i want it to do is climb up and then shut the motor off and glide about a bit, then do it all over again.
will be using a 3 cell 2200mah batt if that helps, the batts weight is in the 900g allready.
many thanks RCT
rcta15 is offline Find More Posts by rcta15
Last edited by rcta15; Mar 24, 2012 at 03:39 AM. Reason: lots of looks but no help?
Old Mar 24, 2012, 06:22 AM
United States, CA, Rocklin
Joined Jan 2006
Hi RCT,
I like Hyperion motors so here's some data for you to peruse at your leisure...
Your plane weighs in just a bit under 2 pounds and a basic rule of thumb for sport flying is a motor producing 100 watts per pound. I would look at the following link;
http://media.hyperion.hk/dn/gs/GSpropdata.pdf
and choose from one of the 22xx-xx motors listed. They all are able to sustain 200+ watts, it's just a matter of your prop choice, and your batteries ability to provide the amps the motors wish to draw.
Happy flying to you,
gofish
gofish is offline Find More Posts by gofish
Old Mar 24, 2012, 07:08 AM
Joined Jan 2009
Originally Posted by gofish View Post
Hi RCT,
gofish
many many thanks thats great.
RCT
Old Mar 24, 2012, 07:41 AM
Joined Jan 2006
Sure thing RCT, and thanks to you, I've reached the 1k post milestone
Help! prop recomendation needed please? rcta15 Foamies (Scratchbuilt) 2 Oct 30, 2011 02:00 AM
Discussion Please recomend me a glider. E-reevo Electric Sailplanes 20 Sep 24, 2010 03:46 PM
Question Which motor for a 900g / 29oz EPP jet ??? Robert77 Power Systems 3 Apr 05, 2010 11:43 AM
For Sale Easy glider, motor, speed control, prop, battery, plus a new prop set Ron Cate Aircraft - Electric - Power Systems (FS/W) 0 Feb 10, 2008 01:41 PM
Question Recomend a micro glider for gws ips power topforce Electric Sailplanes 8 Aug 26, 2006 01:49 PM
