Old Jul 24, 2014, 04:55 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Mini-HowTo
Flip 32+ User Manual
I have a Flip32+ on order from Paul and decided to create a user manual instead of always having to rely on Naze32 manuals and forums to get the information needed for setting it up.
Please do not reply to this thread. If you have a question or a helpful tip/hints, please PM me. I would like to keep this thread as having one message only, this one.
Any and all updates will be posted on this message so stay tuned
UPDATE 07/24/2014:
Flip 32+ has shipped and should arrive within 3 days.
UPDATE 08/04/2014:
Flip 32+ manual uploaded.
UPDATE 07/26/2014:
Flip 32+ received and manual started.
UPDATE 08/01/2014:
Manual is done and am in process of final editing.
UPDATE 08/11/2014:
A reader named Mark notified me that there is a discrepancy in the motor layout picture for motors 3 and 4. Motors 3 and 4 are mislabeled in the picture however their spin directions are correct. I will correct the manual this evening and re-post as version IV.
UPDATE 11/15/2014:
I posted a new version (V5) of the manual in response to the following:
1. A reader informed me that the VBATT pins on their Flip32+ were different
2. A company by the name of queenhobby has illegally replaced the header on the manual and posted it on their site as if I had written it for them, which i did not. I added verbiage to the header and footers of the manual.
rcjose is offline Find More Posts by rcjose
Old Nov 20, 2014, 11:55 PM
miguel_vice is offline
Find More Posts by miguel_vice
miguel_vice's Avatar
Dallas TX
Joined Feb 2007
Gracias Jose, this is awesome.
miguel_vice is offline Find More Posts by miguel_vice
Old Nov 24, 2014, 12:38 AM
wuudogg is offline
Find More Posts by wuudogg
wuudogg's Avatar
United States, VA, Leesburg
Joined Aug 2002
Nice manual. You should send it to Paul at RTFQ.
wuudogg is offline Find More Posts by wuudogg
Old Dec 20, 2014, 05:26 PM
kork123 is offline
Find More Posts by kork123
Joined Aug 2007
Isnt the + and - pins reversed in your manual for the vbat and beeper connections? I tried hooking my battery like it states in this manual and got smoke.... Luck have it that i did no fry anything...
kork123 is offline Find More Posts by kork123
Old Jan 02, 2015, 10:30 AM
bryanduke is offline
Find More Posts by bryanduke
Pilot of things.
bryanduke's Avatar
United States, CA, Lancaster
Joined Dec 2006
It looks like the Rev 6 boards have the positive battery pin on the inside of the board and the ground is on the outside (aligned with the rest of the motor output ground pins). I connected my Flip32+ Rev 6 following this manual and ended up with some melted pins, a loud pop and smoke. Oops.
After connecting the Vbat backwards, it looked like my board still worked. However, my barometer is always showing about -54,000 feet now. I disabled BARO on all my flight modes and the board is flying fine. For $27 though, I'm just going to replace the Flip32+ to make sure I don't run into another problem because of the big voltage I sent to the ground plane with my backwards Vbat connection attempt. I'd really hate to lose another component while my quad is flying.
The Rev 6 board has a little "+" next to the Vbatt pins. The + is right next to the positive pin.
bryanduke is offline Find More Posts by bryanduke
Old Jan 02, 2015, 01:43 PM
pinoydad is online now
Find More Posts by pinoydad
United States, CA, Auburn
Joined Jan 2009
posted this to another thread but can get comments maybe i was in the wrong place ..
i have both buzzer and led intended for kk board ..tested them both to my dragonly32and they wrk ..question is ..is it ok to "Y" them together to have them both work w/ out issues to the board or draw too much
EDIT..would this be a problem?..any one ..just making sure dont wanna see the magic smoke show right now
pinoydad is online now Find More Posts by pinoydad
Old Jan 02, 2015, 02:06 PM
Pilot of things.
bryanduke's Avatar
Joined Dec 2006
That would depend on how much current they draw and how much the Dragonfly provides. Can you measure their current when wired together and compare that to what the Dragonfly can output?
Old Jan 09, 2015, 07:02 PM
photohap is offline
Find More Posts by photohap
United States, WA, Federal Way
Joined Nov 2014
Very good writeup. This would be a good sticky for anyone new and old for the naze boards
photohap is offline Find More Posts by photohap
Old Jan 10, 2015, 03:37 PM
mmccormack58 is offline
Find More Posts by mmccormack58
Joined Feb 2009
RC Jose,
Sorry about the plagiarism issue. I'm glad to have found your thread as I am just starting to work with the Flip 32. I like what I see so far and thank you for your dedication.
Mark
mmccormack58 is offline Find More Posts by mmccormack58
Old Feb 02, 2015, 01:27 AM
Phil06 is offline
Find More Posts by Phil06
Joined Feb 2014
Hi
Great doc very helpful. May I suggest to add some additional information:
a. Can you add some description on connectors just above the I2C one used for Bluetooth. I mean the Serial/UART and SWD one?
b. What are they used for and how can we used them ?
c. Also, how to use FrSky Telemetry with this board would be a plus.
Phil06 is offline Find More Posts by Phil06
Old Feb 14, 2015, 12:01 PM
ClintonRH is offline
Find More Posts by ClintonRH
Joined May 2014
Reply to weeks old post but what the hell, maybe it will help someone else.
I got FrSky telemetry working with Cleanflight by following the info here - https://github.com/cleanflight/clean...docs/Serial.md. Connected telemetry RX (green wire on D4R-II) to Pin 6 (signal on input 6). Only hickup is that I tried to set up the port scenarios through the CLI and everytime the board would reboot with the SAVE command my changes would be gone. Doing it through the Port tab of the configurator worked though. Still had to set the telemetry inversion with CLI though.
ClintonRH is offline Find More Posts by ClintonRH
Old Mar 01, 2015, 06:43 PM
ScooteryB is offline
Find More Posts by ScooteryB
Joined Apr 2004
I think the vbat pins you have indicated are incorrect as I plugged my battery into an otherwise working board in accordance with the diagram and got some magic smoke. I'd recommend you 1) change the manual accordingly or 2) ask that people reference the RTFQ site for his pictures (as they are different and conflicting to your manual).
Just trying to help other people,
Scott
ScooteryB is offline Find More Posts by ScooteryB
Old Mar 02, 2015, 02:24 AM
Mattmax is online now
Find More Posts by Mattmax
Germany
Joined Jun 2013
Scott
it looks if you're right. the VBAT pins are configured differently, as described in the manual on page 12.
the plus/vbat(+) is inside and minus/ground (- or GND) outside, the other way around as the buzzer. it should also be marked on the circuit board.
Mattmax is online now Find More Posts by Mattmax
Old Mar 02, 2015, 09:41 PM
Joined Apr 2004
You're correct. It was marked on my board as you described, but for some reason I followed the manual blindly and white smoked the board.
Old Mar 06, 2015, 03:33 PM
gimbo is offline
Find More Posts by gimbo
Joined Mar 2015
Cppm
I have a little question about CPPM.
I have a FrSky DR4-ii receiver. I know how to connect that for CPPM. But, where on the inputs on the Flip32+ board pins do I connect the cable?
gimbo is offline Find More Posts by gimbo
Wanted OPS Maxi 30 user manual esj12345 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 17, 2014 09:20 AM
Sold Like new Spektrum DX5e Transmitter complete with printed user manual c.cupp2 Aircraft - General - Radio Equipment (FS/W) 2 Feb 04, 2014 03:14 PM
Discussion V202 user manual? Matts175 Mini Multirotors 0 Dec 02, 2013 02:19 AM
Discussion v212 user manual sportybuckeye Multirotor Talk 0 Sep 30, 2013 09:26 PM
