Old Jan 19, 2013, 10:33 PM
hiflying is offline
Find More Posts by hiflying
United States, WV, Hurricane
Joined Nov 2011
Question
micro motor and linear servos?
Hi guys i was hoping someone could tell me where i could buy the micro motors and linear servos for a couple micro planes i have built. Thanks Rick
hiflying is offline Find More Posts by hiflying
Old Jan 19, 2013, 11:41 PM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
hobbyking... are quite cheap and do a good selection of bits... but do a lot of research first to make sure you know exactly what you want.. A lot will depend on the size and weight of what models you've built..
Good info for micros is to be found on the ar6400 threads on this forum
The micro gear is a bit of a minefield, with 3 different sized connectors for gear, different wiring to the pins and even different voltages... so be carefully
Often it will pay to buy a micro model and use its parts for your projects..
In the UK we have the micro SU dsm2 BNF compatible for 42.. that is cheaper than buying all the bits separately
davereap is online now Find More Posts by davereap
Old Jan 20, 2013, 03:10 AM
hiflying is offline
Joined Nov 2011
Thank Dave i will check hk and read the post. Rick
Old Jan 20, 2013, 11:56 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
If it's a three channel airplane you can get the Parkzone Champ fuse with electronics, motor and gearbox for a little over $40US.
Petefoss is offline Find More Posts by Petefoss
Old Jan 20, 2013, 02:42 PM
hiflying is offline
Joined Nov 2011
Thanks pete will see about locating the champ.that would be hard to beat for $40.00. And three channels is what I need. Thanks for the help guys. Rick
Old Jan 20, 2013, 05:14 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Champ Fuselage W/Electronics - $38
UNGN is offline Find More Posts by UNGN
Old Jan 21, 2013, 11:50 AM
hiflying is offline
Joined Nov 2011
Thanks ungn will be ordering a couple
Old Jan 21, 2013, 03:43 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Atm i am building a micro , i am using one of the "arms" from a v929 mini quad and will be using a v911 controller board( comes with 2 servos ) to control it, probably not the lightest of setups but its pretty light and should suit my purposes, plus i already know the motor/gearbox is setup for a 5x3 prop
scousethief is offline Find More Posts by scousethief
Sold Spektrum AR6400L + Linear Servo from PZ Sukhoi XP scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jan 18, 2013 12:33 AM
Question Servo linear or rotary movement fauconnier Micro Helis 1 Jan 03, 2013 01:28 PM
Sold Micro parts Ar6400, linear servo, motor, prop jetfixrguy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 09, 2011 06:10 AM
Sold Parkzone Ultra Micro P-51 Receiver AR6400, Linear Servo and Motor schwimmair Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 27, 2009 12:40 PM
Cool Micro Linear Motors-Servo Usage? easug DIY Electronics 1 Jun 29, 2006 11:11 AM
