Old Mar 25, 2012, 07:41 PM
beemerscoot00 is offline
Find More Posts by beemerscoot00
United States, NC, Mooresboro
Joined Dec 2011
HiTech servos
Can someone tell me about reversing a servo?
I have two HiTech servos for my aeilerons and one failed. I relplaced it with an identical H 65 Hitech but it needs to be reversed so both aeilerons don't deflect in the same direction?? It is identical to the one I removed. I am totally confused?
Thanks in advance for any assistance.
Terry (beemerscoot00@yahoo.com)
beemerscoot00 is offline Find More Posts by beemerscoot00
Old Mar 25, 2012, 08:10 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Are you using a Y cord? If so, you may have the new one turned 180 degrees from how the old one sat. Be sure the servo is positioned correctly and the servo arms are correct.
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Mar 26, 2012, 12:31 AM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
If you are using a 6 channel RX and a computer TX plug one servo in the Aux channel and select 2 servo wing type and then use the servo reverse menu.
600Bob is offline Find More Posts by 600Bob
Old Mar 26, 2012, 02:39 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Reversing a servo can be done, but it requires two sets of wires to be swapped around inside the unit, and is tricky with small servos.
Are you sure your replacement (or the original) is a genuine Hitec one? I've not heard of them rotating different ways. If you've installed the replacement exactly the same orientation as the old one, you need to make sure the servo arm is pointing the opposite way to the one on the other wing -- i.e. both arms should point away from the fuselage, or both should point towards the fuselage. If that's the case, and one aileron is still going the wrong way, the simplest solution is the one posted by 600Bob. Alternatively, you could switch the servo arm round 180 degrees, but that may then require you to move the horn on the aileron sideways so that the pushrod is in line.
abenn is offline Find More Posts by abenn
Old Mar 26, 2012, 11:37 AM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
If the servo arm is on the opposite side of the servo from the other servo arm, they should work correctly on a basic Y-connector. That is very strange.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Mar 28, 2012, 01:27 AM
midnightsabotage is offline
Find More Posts by midnightsabotage
midnightsabotage's Avatar
United States, MN, St Paul
Joined Jan 2011
Can you post a picture or 2 of your new installation showing both servos in the wing so we can better judge if there's any kind of setup issue?
midnightsabotage is offline Find More Posts by midnightsabotage
Old Mar 28, 2012, 10:15 AM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
problem solved?
rcshirt is offline Find More Posts by rcshirt
Discussion HiTech Servo Failure beemerscoot00 Radios 3 Mar 25, 2012 02:55 PM
For Sale HiTech HD Dubro Servo arms & for Metal Gear Servos unclegeorge Aircraft - General - Radio Equipment (FS/W) 1 Mar 05, 2012 11:16 PM
For Sale 3 like new sheathed HiTech 5245mg servos -Elite servos for 500 CHEAP blueindian Aircraft - General - Radio Equipment (FS/W) 0 Jan 15, 2012 05:49 PM
For Sale 3 like new sheathed HiTech 5245mg servos +2cases to send to Hitech >>Elite for 500<<< blueindian Aircraft - Electric - Helis (FS/W) 0 Jan 08, 2012 02:37 AM
Wanted Got any old Hitech or Futaba 500 size servos or clones? S9650 , S9257 Hitech HS5024 ? blueindian Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2012 03:57 PM
