Old Jul 14, 2015, 03:24 PM
Roguedog is offline
Find More Posts by Roguedog
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
I like the T2A. There's something about air scoops that make planes look mean and fast sort of like a P-40 Warhawk.
Roguedog is offline Find More Posts by Roguedog
Old Jul 14, 2015, 07:22 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
My three. dave platt duallist, sharp 45 -80s style and sig king kobra on her way..... all with retracts and electric power systems.
walter3rd is online now Find More Posts by walter3rd
Old Jul 14, 2015, 07:59 PM
Jhl33224 is offline
Find More Posts by Jhl33224
Joined Mar 2012
Nice!
Jhl33224 is offline Find More Posts by Jhl33224
Old Jul 25, 2015, 09:11 AM
NewZee is offline
Find More Posts by NewZee
Foam is my friend!!!
NewZee's Avatar
United States, NY, Depew
Joined Mar 2014
A "Classic" pattern plane with a modern "twist"
Hi All,
Great thread!!! here is my contribution, I did an electric conversion of a 70's vintage "Super Kaos" in addition to the electric power I did a more "modern" Red Bull scheme! here are a few before and after pics!
If anybody is interested my build log is here: http://www.rcgroups.com/forums/showthread.php?t=2363305
and video of maiden flight is here:
Maiden Flight of "Super Kaos" (11 min 13 sec)
NewZee is offline Find More Posts by NewZee
Old Jul 25, 2015, 07:14 PM
bobmrbassman is offline
Find More Posts by bobmrbassman
United States, FL, Chuluota
Joined Jul 2013
I am building a Dirty Birdy 60 from plans. I have the fuselage well on the way , the foam core wing covered with balsa and the halves together and the retracts installed and the cutouts and mounts for the aileron servos done. The horizontal stabilizer is also foam and covered with balsa. The nose gear retract is installed and the servo temp. Installed hooked up and tested.
I am using a period OS 60 for power I think it is from the 60's or early 70's. It runs great and has excellent idle. I bought it off eBay.
I plan to use my old Kraft 5 channel with three original servos with two new servos on ailerons and two new retract servos. I'm not sure of the present rules on frequency but this one is in the 50 MHz band so that may not be affected since I am a ham.
This is my first 60 size model but I flew a dirty birdy 40 and a Taurus years ago.
I plan to cover it with towerkote but might paint the body if I can find a match for towerkote red.
Bob
https://www.dropbox.com/s/nu1pcom44d...45.17.jpg?dl=0
bobmrbassman is offline Find More Posts by bobmrbassman
Old Jul 25, 2015, 10:53 PM
doxilia is offline
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Bob,
My two cents would be to dispense with the Towerkote and use a brand covering material. The TK will peel off and the pigment will eventually "wash out". If you plan to use a base white paint for the fuse, you can cover the wing and stab without the match being much of an issue. You can paint the trim colours on the surfaces to match the fuse paint.
If you are looking for quality paint with a perfect match to MK, contact Kevin at Wings West. He can set you up with paint and primer and even glass cloth and resin. He can ship you paint in an aerosol can or for an HPLV gun.
David
doxilia is offline Find More Posts by doxilia
Old Jul 26, 2015, 01:30 AM
Fatherof4 is offline
Find More Posts by Fatherof4
Raised on 80's Pattern
Fatherof4's Avatar
Rancho Santa Margarita, CA
Joined May 2006
Originally Posted by doxilia View Post
Bob,
David
Thanks for posting. Pictures please. Agree with David.
Call Kevin, he'll set you up.
http://www.wingswestrc.com/shop/unca...matched-paint/
Fatherof4 is offline Find More Posts by Fatherof4
Old Jul 27, 2015, 01:49 PM
walter3rd's Avatar
Joined Aug 2012
I have had pretty good luck with ultracoat as well. Sig king Kobra getting her colors started.
Old Aug 07, 2015, 04:20 PM
Joined Jul 2013
Thanks guys, I appreciate the advice. I used monokote 35 years ago but heard from guys on this forum that it wasn't the same and wasn't worth bothering with. I chose towerkote for economical reasons and I may not be around another 30 years. Monokote loosened up and came apart over time too. Also silk and dope. so I guess I'll try the towerkote since I've. Already got it and if it isn't satufactory, I'll try something else. I used monokote on a couple of planes since my Taurus and liked it so I may try that again if the tower doesn't work.
Bob
I posted a picture on my previous post of my present project.
Discussion Making Molds of Classic Pattern Plane Fuselages & Parts to Keep them Alive for all of Pitstop000 Classic Pattern Flying 627 Jul 29, 2015 09:59 AM
Alert “ Classic RC Pattern Flying Forum on RCGroups ” Pitstop000 Competition Aerobatics 60 Apr 12, 2011 02:49 PM
Discussion 'Baby' classic pattern plane kits are here EAC Competition Aerobatics 7 Dec 30, 2010 05:17 PM
Contest Tangerine pattern classic Thermaleer Competition Aerobatics 0 Nov 01, 2010 08:43 AM
Discussion Classic pattern plane MK Blue Angel customcarmaker Competition Aerobatics 10 Oct 29, 2010 01:52 AM
