Old Feb 05, 2013, 01:44 PM
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
If your not sanding, your not building .
Mark
the goon is online now Find More Posts by the goon
Old Feb 05, 2013, 03:34 PM
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
Nice work! I started with the same kit a few years ago and made a few minor mods to make it look more like a fishing boat. I've built a few midwest kits, they're great! Keep up the good work, should be a great boat when its finished.
catchthis is offline Find More Posts by catchthis
Old Feb 25, 2013, 10:52 AM
Crackin' Claws
STONECRAB's Avatar
United States, FL, Oviedo
Joined Oct 2012
Progress photos
Hi again,
I'm posting these new photos to see what you all think about my progress, and the way I have gone about setting up my electronics and motor.
The shelf for the ESC, on/off switch, and receiver is pressure fit and removable.
Also, the holes I have drilled are for ventilation for the speed controller, which brings me to a question.
Does anyone know if it would be necessary for me to install a small fan for air circulation, and if so can I power it from the third channel on the receiver?
Also, suggestions for type of fan, if needed.
This being my first build, any feedback is greatly appreciated.
PS Weather permiting, I will prime my hull today and install the cabin sides which are already finished and fitted!
STONECRAB is online now Find More Posts by STONECRAB
Old Feb 25, 2013, 11:50 AM
---o-O-o---
blutoh's Avatar
United States, NJ, Livingston
Joined Mar 2012
Barry,
Looks great! What's your color scheme going to be?
Pete
blutoh is online now Find More Posts by blutoh
Old Feb 25, 2013, 01:16 PM
Crackin' Claws
STONECRAB's Avatar
Joined Oct 2012
Thanks, Pete!
White gloss hull, cockpit, and cabin.
Navy blue gloss bottom, cockpit and cabin roof.
Satin gray decks and red gloss water line.
I just finished priming the hull and there is just a little touch up filling needed.
I can't wait to build out the cockpit and cabin!
I'll post more photos again soon.
Thanks for taking a look.
Old Mar 02, 2013, 11:42 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
If the ESC is getting hot, then consider putting a fan on it.
You should be able to find some small 5-12volt fans that you could run
directly off the batteries. I would avoid drawing too much power through
the receiver. It doesn't tolerate a lot of amperage.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Mar 03, 2013, 12:07 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Hi Barry,
I use that same ESC in a fishing trawler with a low RPM Dumas motor, and it works fine and never over heats.
But you are using a high RPM motor, I presume. So the current draw may be significant.
One thing to realize, and remember, is that small props can make big speed. I know it seems counter intuitive. But a small prop allows the motor to rev higher, using less current. A small prop turning high rpm is just as good as a bigger prop turning lower rpm. However, if the lower rpm is the result of a high rpm motor straining to turn it, that will create heat and damage.
Always start out with a small prop. Smaller than you think is reasonable. You might be surprised at the performance. And remember, you can always prop up in size again. But if you start with a too large prop to begin with, you may find the boat does not perform well and you may cook your esc and motor in the process.
Kmot is offline Find More Posts by Kmot
Old Mar 03, 2013, 07:06 PM
Crackin' Claws
STONECRAB's Avatar
Joined Oct 2012
Umi and Kmot, thank you for your information.
It has clarified what I need to know concerning my lobster boat build.
Everyone on RC Groups seems to be selflessly helpful, and that tremendously contributes to making this hobby so much darn fun!
Rave I'm in Looove Axefly Multirotor Talk 0 Feb 02, 2013 01:19 AM
For Sale M&M Wedgie - New in Box SoaringBoulder Aircraft - Electric - Airplanes (FS/W) 2 Jan 11, 2008 12:36 PM
