Old Apr 20, 2015, 08:30 AM
JediKnight2 is offline
Find More Posts by JediKnight2
I'm Bonafide!
JediKnight2's Avatar
Wilmington, NC
Joined Aug 2005
Here's a video of my Sbus issue....I've even flashed the newest firmware to my Rx. Flashed the latest FrSky firmware to my radio, I've tried OpenTx 2.0.15 as well. The video cuts short, but i was basically saying nothing's working on the Sbus...LOL
https://drive.google.com/file/d/0B71...ew?usp=sharing
JediKnight2 is offline Find More Posts by JediKnight2
Old Apr 20, 2015, 11:10 AM
kapu is offline
Find More Posts by kapu
United States, WA, Seattle
Joined Dec 2013
Originally Posted by moody07747 View Post
Will double check the arduino code, GUI shows it's active and my switches are mapped properly, but yeah last flight, I flipped it to position hold, took my hands off the sticks, and it drifted 10 feet to the right before I took control again.
When you say "drift", it is important to clarify if you mean that you have a position fix that wanders over time, or if you have oscillation back and forth. The latter is probably tunable with PIDs, the former maybe, maybe not. GPS performance varies with geographical location, cloud cover, and wind conditions of course, but you should not expect GPS hold to be perfectly precise. You need to test in a safe location and conditions (preferably calm winds) where you can let it do it's thing and see what the hold radius really is. Mine works very well, but I would consider +/- 10 lateral feet to be a good hold. GPS hold is not something you can safely use close to the ground or other obstacles (neither is alt hold).
One way to see what the actual position fix drift is (as opposed to the PID correction drift) is to use a GUI in the field, like the android EZ GUI ground station, and see how it does on the ground. Pull up the map display, and see how much the GPS track wanders when the multirotor is sitting still. You will never be able to improve on that performance with tuning. It can be quite different on different days and locations, depending on the satellite signal reception.
kapu is offline Find More Posts by kapu
Old Apr 20, 2015, 11:13 AM
kapu is offline
Joined Dec 2013
Originally Posted by jlremr View Post
When does GPS establish the HOME location, when battery is plugged in or when
ARM is selected.
John
Home position is set at arming. It can't happen at power up, because it takes time to get a sat fix. If you arm before you have a good fix, you may get a bad home position. If you want to reset home, just rearm.
Old Apr 23, 2015, 09:06 PM
I'm Bonafide!
Wilmington, NC
Joined Aug 2005
I believe I found my SBUS issue....I do NOT think I did this when I soldered the pin header on. I use minimal heat and have soldered much finer components than a pin header....I might try to get this back on, but I don't know if I can trust it...It will fly fine in non-SBUS mode though so the board isn't totally toast and can make a good backup I guess. The resistor checks out OK, it's just not on the pads on one end, the other end is soldered to the pad. Basically, my SBUS signal isn't getting through to the RX port. I don't have a reflow station either so it's going to be a PAIN to work on if I decide to fix it.
Old Apr 24, 2015, 11:19 AM
umdpru is offline
Find More Posts by umdpru
umdpru's Avatar
United States, MA, Boston
Joined Jun 2006
you don't need a reflow station to fix that. A decent SMALL soldering iron tip set at the right temperature and quick work with the iron and tweezers would fix it.
umdpru is offline Find More Posts by umdpru
Discussion Witespy Pro2 & Pro3 Flight Controllers for MegaPirate Next Generation (MPNG) Greg Covey Multirotor Electronics 353 Apr 24, 2015 04:28 PM
For Sale MultiWii PRO 2.0 flight controller w/gps. mando608 Aircraft - Electric - Multirotor (FS/W) 3 Feb 27, 2014 09:48 AM
Discussion sk-450 + MultiWii PRO 2.0 Flight Controller wont get off ground any ideas ? smz Multirotor Talk 17 Jan 16, 2014 05:21 AM
Sold MultiWii PRO 2.0 Flight Controller w/ GPS Option xhover Aircraft - Electric - Multirotor (FS/W) 1 Jan 21, 2013 03:24 PM
Discussion Witespy MWC Pro v2.0 HeliCopCR1 Multirotor Electronics 11 Jan 06, 2013 05:09 PM
