Old Feb 01, 2015, 05:41 AM
jabram's Avatar
Australia, NSW, Kendall
Joined Jul 2012
RCTimer Y6 Tri-Trooper 900mm Carbon Fiber Frame - Integrated PCB Version
Specifications:
- 30 mm carbon fibre booms
- 2.5mm carbon fibre Mount(Battery and Gimbal) plate
- Injection moulded motor mounts
- Flight controller position between the frame plates
- Pre-drilled for 45x45 flight controller patterns
- 28 mm to 54 mm motor size
- INERTiC camera mounts
- 20 mm carbon fiber landing poles
- 900mm size
- Y6 shape
- Frame weight: 1159g
Main Board:
6 ESC Distribution board
XT60 Connector
6050 mould for 32 BIT Brushless GIMBAL
LED 1W
LED module socket for ESC and Motor
Gopro AV singnal input
12V 3A BEC output & AV singnal input (1 way socket provides AVOUT /12V/GND for FPV, other three only provides 12V output function)
5V 3A BEC output & AV singnal input (1 way socket provides AVOUT /5V/GND, for FPV, other three only provides 5V output function)
Battery Voltage Tester
Frame Manual: Here
PCB Board manual: Here
jabram is offline Find More Posts by jabram
jabram's Avatar
Joined Jul 2012
Old Feb 01, 2015, 05:42 AM
jabram's Avatar
Joined Jul 2012
Old Feb 01, 2015, 05:43 AM
jabram's Avatar
Joined Jul 2012
jabram's Avatar
Joined Jul 2012
Old Feb 01, 2015, 06:54 AM
jabram's Avatar
Joined Jul 2012
Old Feb 02, 2015, 02:09 AM
jabram's Avatar
Joined Jul 2012
Old Feb 05, 2015, 08:05 AM
jabram's Avatar
Joined Jul 2012
place holder
Old Feb 18, 2015, 05:20 AM
Italy, Friuli-Venezia Giulia, Trieste
Joined Aug 2013
Hi jabram
Nice build!
Can I ask you why did you use X6 motors and which props did you use?
I saw on RCTimer they suggest X5 motors and 14-16 inch props..
X6 with 17x5.5 @22.3A is told to pull 2.6Kg that is 15Kg!!
Did you try some flight time with your setup??
Pietro
pieri70 is online now Find More Posts by pieri70
Old Feb 18, 2015, 05:06 PM
jabram's Avatar
Joined Jul 2012
Originally Posted by pieri70 View Post
Hi jabram
Nice build!
Pietro
Hi Pietro,
Thanks, I used X6 motors because that is what I had on hand that would fit.
The plastic motor mounts only suit very few motors with the exact mounting hole placement, unless you have a serious workshop and are going to make some plates to fit other motors for example this Y6 build by 1hander http://www.rcgroups.com/forums/showthread.php?t=2273614
I tried many different prop combinations, finally ended up with CF 15x5.5 top and bottom.
No, I have not done flight time tests on the Y6.
Old Feb 19, 2015, 05:03 AM
Joined Aug 2013
Originally Posted by jabram View Post
Hi Pietro,
Ok that was just curiosity, because on RCTimer site they told me to use X5 motors..
They weight a lot less than the X6 and develop a good pull power..
145g vs 240g each that is 570g total weight
according to this table
they have 950g trust @4.4A with a 15x5.5" prop
So more or less 27 minutes for hovering with a 5700g uav..
Just my thoughts..
Let me know how much time you can fly with your setup!!
Thanks!
New Product RCTimer Y6 Tri-Trooper 900 Carbon Fiber Frame - Integrated PCB Version Askyvision Multirotor Talk 903 Today 10:29 AM
Sold Trooper Y6 900mm with KDE DIRECT 3510-475kv motors Reduced $$ volksrule Aircraft - Electric - Multirotor (FS/W) 6 Nov 02, 2014 03:29 PM
Sold Trooper Y6 900mm with KDE DIRECT 3510-475kv motors volksrule Aircraft - Electric - Multirotor (FS/W) 9 Oct 27, 2014 02:10 AM
For Sale esc32 , carbon fiber tri (y6)REDUCED Cc3dpilot Aircraft - Electric - Multirotor (FS/W) 0 Mar 08, 2014 09:34 AM
Sold H550 V2 Glass Fiber Hexcopter Frame 550mm - Integrated PCB Version kayvannouri Aircraft - Electric - Multirotor (FS/W) 0 Jun 18, 2013 07:27 PM
