Old Feb 24, 2015, 09:31 PM
like freakin' NASA in there.
Jmel's Avatar
United States, NC, Winterville
Joined Jul 2014
I agree on the grass field part. I use a GPS Logger. Bought off eBay for 30 - works well enough. Miller convinced me on the Waco motor and prop. His flies great with it. I've not installed yet, it's all ready to go after I do a speed reading on the original stock setup. Then I'm going to do another after the install.
Jmel is online now Find More Posts by Jmel
Old Feb 24, 2015, 10:51 PM
Yes it was Abby Normal
Joined May 2012
Aye very good Jmel....so we may have a first here with some good data comparisons. Very interested in your results both on 4s power.
So you are hopping up to the Kv650 motor and the XOAR 13x6.5 prop?
I need to look into a GPS logger for myself and see what the stock Kv900 motor is delivering!!
TwistedGrin
TwistedGrin is online now Find More Posts by TwistedGrin
Old Feb 25, 2015, 09:55 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Lower kv and larger prop would do this plane some good. So I am sure that the Waco set up would work pretty good. There are some rocket motors that I am tempted to try out that would drop right into this plane. If I had decided to get nutty with it then that is the route that I would go! However I am loving it as it is now! I don't see a need to change it! Especially when there are 4 or 5 flying together like it usually is at my field. It is cool to see us all thottle up and stay there with eachother in a big pack instead of one or 2 shooting off into the distance. It makes it more competitive and fun!
gooniac33 is online now Find More Posts by gooniac33
Old Feb 25, 2015, 11:45 AM
Jmel's Avatar
Joined Jul 2014
Yeah I am having to put the waco motor and 13x6.5 prop in to keep up with Miller
I flew same as he did the other day with him, and I was at full throttle the whole time. He landed at 3.8v or so, I was way past danger zone at 2.8! This was with mine completely stock and his with Waco and 13x6.5
Old Feb 25, 2015, 01:49 PM
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Alright, first I want to be clear that I'm not arguing with anyone, or denying Miller's results, because I haven't tried them. But ...
I just don't see how it's possible that the plane is faster on a 650kV motor with a 6.5" pitch than on a 900kV motor with a 6" pitch. The math says it should be about 20% slower. I know that's not the whole story but still ...
What's going on here?
mclarkson is offline Find More Posts by mclarkson
Old Feb 25, 2015, 02:03 PM
teaching to learn
millerr74's Avatar
United States, NC, Greenville
Joined Oct 2013
Mclarkson, my hypothesis is that due to the waco motor being a bigger can, it has more power and thus spins the prop at full capacity. The stock 900kv motor is a smaller can and most likely doesn't actually turn the prop at the rated rpms. So the math as you calculated it would indicate that the 900kv would spin the prop faster than the 650kv motor, but the real world application seems to result in an actual faster prop with the lower kv because it has more power and therefore is more efficient / effective at spinning the prop.
millerr74 is online now Find More Posts by millerr74
Old Feb 25, 2015, 02:05 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Alright. As I said, I wasn't doubting you. The results just seemed .... odd.
Old Feb 25, 2015, 02:10 PM
teaching to learn
millerr74's Avatar
Joined Oct 2013
Yes, we're investigating a mystery here. Does my proposed explanation make sense in this application?
Old Feb 25, 2015, 03:04 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
It makes sense but also makes me think that a higher pitch prop may actually work better on that motor. I was actually thinking of getting a motor that will spin a 12x12 on 3s....
Old Feb 25, 2015, 03:44 PM
teaching to learn
millerr74's Avatar
Joined Oct 2013
Wow! 12x12 sure would be a sight to see before the whole power plant explodes into a pyrotechnic masterpiece . Make sure you get it on video goon.
Old Feb 25, 2015, 04:05 PM
Jmel's Avatar
Joined Jul 2014
I think there should be a little room to grow in the 12 inch prop arena, since the 6 pitch is only chomping at 27a. Isn't the stock ESC a 40a?
Also, I went with lucky 13, since Miller had lucky 7.
Einstein is quite comfortable in the pilot seat.
Description:
Old Feb 26, 2015, 01:11 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
There are quite a few motors capable of doing that. But I need to see if they will work on this model. I had that set up on a Parkzone Trojan back in the days. on 3s it was a beast and on 4s insane!!! the rate of climb was like a hotliner! I wouldn't run 4s on the Gee Bee with that set up but 3s would be perfect.
Old Feb 26, 2015, 01:38 PM
teaching to learn
millerr74's Avatar
Joined Oct 2013
I got you on that gooniac. I missed the part you said about using a different motor with your 12x12. I thought that you were going to just pop it on the stock motor and have at it.
Mini-Review Nitroplanes.com Dynam 4 Channel Dynam SU-26M 47'' Brushless Sportsplane Nitro_Nancy Sport Planes 1 Oct 06, 2012 12:18 PM
Question Dynam transmitter used on all dynam planes? or just the one it came with? Dominick Zola Electric Plane Talk 5 Apr 12, 2012 11:05 AM
Question DYNAM SU-26 and DYNAM PITTS/PEAKS ? pc_pilot Nitro Planes 3 Mar 29, 2012 10:32 PM
Wanted Super Sportster & Sportster Bipe Plans. Stephen Bennett Aircraft - Fuel - Airplanes (FS/W) 2 May 18, 2008 04:22 AM
need stuff for mini geebe lilpols charger prop rx and new flyer Aircraft - Electric - Airplanes (FS/W) 7 Sep 16, 2004 03:51 PM
