Old Oct 05, 2012, 09:50 AM
Portugal, Braga, Vila Nova de Famalic„o
Joined Oct 2009
Help!
voltage regulator to servo
Hi
I have a step down voltage regulator that i want to connect to a servo.
Can someone please explain me how i should do the wiring?
thanks
best regards
Jose
oacilamaf is offline Find More Posts by oacilamaf
Old Oct 05, 2012, 11:12 AM
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Just a single servo? I would think you would want to connect the entire rx. Or is it for a HV servo?
boaterguy is online now Find More Posts by boaterguy
Old Oct 05, 2012, 11:21 AM
Joined Oct 2009
yes, just a single servo.
Its a normal servo, i just want it to move slower.
Can you help me with the wiring?
Old Oct 05, 2012, 11:53 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I don't think a servo will work at less than 5V very reliably. You can buy servo slowing devices at servocity.com I think.
I'm not certain on the wiring.
Old Oct 05, 2012, 12:44 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
just look at the shown picture !!!
http://www.ebay.com/itm/LM2596-DC-Co...-/220877514845
YESSSSSS !!!
Alain
Acetronics is offline Find More Posts by Acetronics
Old Oct 05, 2012, 03:44 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
He means how to wire it to supply power to a servo while using a different power supply for the RX.
Old Oct 06, 2012, 06:37 AM
Joined Oct 2009
Not so simple wiring a servo to a voltage regulator. obviously my first try was to connect positive to negative on both in and out but it didnt work. It wil only work if i make contact between the white wire (if it is connected all the time it wont work)
Any suggestion?
Old Oct 06, 2012, 08:14 AM
Aberdeen, Scotland, UK
Joined Dec 2007
You purchased the wrong bit of kit. Bad idea to limit the supply voltage to a servo with the idea of slowing it down.
What you need is a servo rate adjuster.......here's an example.
http://www.graysonhobby.com/catalog/...ter-p-421.html
Ian.
IanJ is offline Find More Posts by IanJ
Old Oct 06, 2012, 12:08 PM
Joined Oct 2009
i was only slowing it down to 4.8v so i think there is no problem, am i right?
So, the voltage regulator wont work with servo or is it just to difficuld to worth it?
One more thing, can i suply power directly to the servo? how?
Old Oct 06, 2012, 12:48 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
No real problem till your voltage stays > 4v3 ...
just loss of torque ( take care not to be too close to stall ... ) . But being honest ... speed reduction is not really noticeable il load is light.
so, your "solution" is ... " not so good " ...
Alain
Old Oct 06, 2012, 03:07 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
If you really want to do that, just run the RX off 4v8 as well.
But, you won't notice a difference.
For example, look at the numbers on this servo:
http://www.hobbyking.com/hobbyking/s...dProduct=16266
By dropping to 4.8v, you've added 1/100th of a second to the time at no load. That wouldn't even be detectable by human standards.
Old Oct 07, 2012, 05:30 AM
Joined Oct 2009
In that case it wont make much of a difference but in my servo it makes a noticeable difference...
I found out that in order for it to work you need to share a common ground between the signal wire and the negative pole.
Old Oct 07, 2012, 08:28 AM
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
I believe that is the same module I grabbed early on from Digikey. It did not last long since running with no output load, (voltmeter only) had it fry.
All the previous recommendations are correct. Trying to set servo sweep speed with input voltage is the wrong method for many reasons. That's why the very inexpensive servo slower from HK is far less problematic.
The only problem with those is the update speed does not play well with digital servos and makes them rather notchy.
p.s. A lot of programmable transmitters now have servo speed options you can set yourself.
Cougar429 is online now Find More Posts by Cougar429
Old Oct 07, 2012, 09:31 AM
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
As the other guys here are trying to explain, a "normal" servo cannot be slowed down by simply reducing or adjusting the voltage going to it. That's just not how they work. Google "Pulse Width Modulation" or "PWM" for an explaination of how it works. The voltage going to the servo is constant, it does not vary. The 3rd wire from the receiver, the signal wire, carries a pulse that tells the servo where it's supposed to be. If the servo isn't already there, it tries to get there as quickly as it can. If you want to slow a normal servo down, you have to have a device that intercepts that signal and sends it to the servo in increments over a longer period of time. Some are adjustable, some aren't, but they all work the same way, and as for wiring, they are simply inserted between the servo and the receiver.
Reducing the voltage will cause lots of problems and could even damage the servo eventually.
dmccormick001 is offline Find More Posts by dmccormick001
Old Oct 07, 2012, 10:19 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
If you had some EE experience you could even get to the point of wiring one up yourself with a microcontroller.
Wanted Voltage Regulators for Fuataba S9254 Tail servo mmalik4 Aircraft - Electric - Helis (FS/W) 1 May 10, 2011 08:12 PM
For Sale Hitec , Futaba , JR servos and Duralite Voltage Regulator rcgalore Aircraft - General - Radio Equipment (FS/W) 2 Jan 09, 2011 10:05 PM
New Product Introducing 5v Gyro/Tail Servo Voltage Regulator - Helicopters perfectregulat Product Announcements 1 Jun 04, 2008 03:53 PM
