Old Jun 27, 2014, 04:46 PM
United States, NC, Mars Hill
Joined Mar 2009
Re-soldering motor leads-Turnigy 2730 1500
Hi, I recently obtained a GWS SS with a Turnigy 2730 1500kv motor, but one of the motor leads has become separated from the wire.. is this fixable?
cmdr199212 is offline Find More Posts by cmdr199212
Old Jun 27, 2014, 05:42 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
yes in most cases. If you can carefully unwind the damaged strand a couple of turns off the stator to get enough to work with. the new exposed wire will have enamel coating that needs to be removed a little from the end so solder will take. You can scrape the enamel off with an exacto knife. I had asked years ago about if all 3 phases were wound different (turn counts were different) if it was harmful and the consensus was that it was minor. Hope this is helpful.
Blazer
BlazerB52 is offline Find More Posts by BlazerB52
Old Jun 27, 2014, 09:37 PM
Joined Mar 2009
I've never done soldering before.. I also don't have an iron, and being a college student have limited storage etc.. would it be more prudent for now just to purchase a new one?
Old Jun 28, 2014, 05:46 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
Pictures of the patient?
Use aspirin trick
(Re)winding and building motors
-> opening post
-> #27 Removing magnet wire insulation can be ...
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jun 28, 2014, 07:29 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
If you plan on staying long term in this hobby it would be a good idea to have something to solder with. It is not hard to solder. And you need just a few items to do soldering.
Ron,
I keep a bottle of asprin at my solder bench just for magnet wire.
Fumes are brutal tho.
Old Jun 28, 2014, 07:59 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
Here are a few tools you need.
Old Jun 28, 2014, 10:41 PM
Joined Mar 2009
Awesome, thanks Blazer! Someday soon.. I shall acquire those!
Sold Turnigy 2730-1500 brushless motor ShoGinn Aircraft - Electric - Power Systems (FS/W) 1 Nov 28, 2012 09:23 AM
Sold Turnigy Plush 12A ESC w./ 2730-1500 motor NorthwestWolf Aircraft - Electric - Power Systems (FS/W) 4 Oct 05, 2012 08:46 PM
Wanted turnigy 2730-1500 motor beercandan11 Aircraft - Electric - Power Systems (FS/W) 0 Jul 09, 2012 11:58 PM
Mini-Review HXT 2730-1500 (~1690Kv) and Turnigy R&B 2730-1500 (~1600Kv) Dr Kiwi Power Systems 73 Mar 07, 2012 05:14 PM
Sold Turnigy 2730-1500 motor dizzane Aircraft - Electric - Power Systems (FS/W) 3 Oct 11, 2011 10:03 AM
