Old Apr 07, 2013, 09:31 PM
Joined Mar 2011
Motor Mixing Problem
Hi Guys,
Can any help me with a motor mixing problem.
Our task is to design an ROV, but it must have vectored thrusters as shown in picture.
The picture also shows what motors must turn depending on the direction of the joystick.
Can anyone advise me on how I would mix the 5 ESC to achieve this.
Much apprecaited
Yorkie.
yorkie1 is offline Find More Posts by yorkie1
Old Apr 09, 2013, 05:47 AM
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Hi Yorkie
I replied to your PM, just for others info Yorkie is going to use servocommander for control so if anyone has experience with this chip in.
Mmmm shame they dont do a demo of the software that had no output/limited time use or something like that so I could play about with some cross channel mixing..
robe_uk is offline Find More Posts by robe_uk
Old Apr 09, 2013, 06:38 AM
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Try this just to see what the servocommander software does, just working with Joystick B to start with.
Lets begin by defining what channels the esc are actually are connected to,
motor 1 = channel 11
motor 2 = channel 12
motor 3 = channel 13
motor 4 = channel 14
Now assign the joystick axis to a channel
Axis 1 (forward/backward) = channel 1
Axis 2 (left/right) = channel 2
Right here things get a bit messy, as some mixing is required and the motors are required to rotate in opposite directions depending on position of the joystick, so we will have to use and addition channel that has been inverted to aid in mixing, I will use channel 3, see picture where to invert.
So to move forward/backward
channel 1 mix channels 11+12+13+14
now the left/right
channel 3 mix channels 12+13
channel 2 mix channels 3+11+14 (because the channel 3 is inverted motors 2 and 3, remember we assigned them to channels 12 and 13, will spin the opposite way to 1 and 4)
Well try that and let us know how the software behaves, hopefully it will SUM the mixes to the esc's and give smooth control, if this works I may be tempted to change direction on my own project.
Good Luck
Rob
Old Apr 09, 2013, 08:16 AM
Joined Mar 2011
Thanks Rob, very much appreciated.
I have yet to receive the servo controller to test this, but it kinda makes sense.
Like I said in the PM, this is my weakest field.
I was under the impression you could only mix TWO channels.....lol, this was my confusion...
As soon as I get hooked up I will post on how I got on, I'm purely bench testing at the mo, with electronics, the build will probably start in the summer.
Once again, thank you very much for your time.
Cheers
Yorkie
Discussion Walkera Ladybird motor problem Frank183 Mini Multirotors 11 Dec 17, 2013 10:07 AM
Help! Futaba 8FG p-mix to camber problem. warhawk.cz Radios 5 May 03, 2013 12:35 AM
Help! HP6DSM Elevon Mixing Problem rnaef77 Beginner Training Area (Aircraft-Electric) 5 Jan 09, 2013 05:19 PM
Help! Main motor proportional mix trimmer problem revo.tmaxx Coaxial Helicopters 1 Aug 20, 2006 08:01 AM
