Old May 31, 2009, 10:37 PM
Las Vegas, NV
Joined Mar 2008
Build Log
"Hot Hots" build
Starting a new build project. It will replace my deceased sport/"toss around" plane that I "dumb thumbed" in a few weeks ago. Motor and radio gear from that plane will be used here.
It's a 3D, sport flyer that originally appeared as a build article in a 2002 RCM. I picked up the kit from a fellow flyer that had it for several years. He didn't have any plans, other than the partial, reduced print in the magazine article, but he loaned me his already built example to help figure it out.
The original plane, from the build article:
Basic fuselage construction begins:
Fitting motor and fuel tank. Not much room to work with:
Landing gear will be held in place with stainless steel threaded inserts and bolts.
aft wing attach plate installed:
Over all look to this point:
hammerd is offline Find More Posts by hammerd
Old Jun 01, 2009, 08:52 AM
Closed Account
Joined Dec 2006
Doesn't look a whole lot different then the original "The HOTS" designed by Dan Santich, back in the 80s. One of my favorite airplanes. Built one from a Midwest Kit in 1986 and from plans in 2005. Lightness is your friend! What is this version powered with? The original was designed for .40.
The original was a one piece airplane and was small enough this wasn't a problem.
Mode One is offline Find More Posts by Mode One
Old Jun 01, 2009, 11:12 AM
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Hammerd,
Nice plane!
Your building board is very nice as well. Is the metal top boned to the wood that it is resting on in the pic? Also, what gauge metal did you go with? Are your clamping structures made from high density polyethylene?
Thanks!
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jun 01, 2009, 01:58 PM
Las Vegas, NV
Joined Mar 2008
Same guy designed this plane. He has designed several different versions, and now his son is carrying on with it. I'm putting my OS 46AX in this one.
Hot Hots Website
My building board is 18GA "paint lock", glued to a lamination of MDF. Ridiculously heavy, but very straight and stable. The angles are cut from 1/4" acrylic.
Old Jun 01, 2009, 02:09 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks Hammerd,
I'm going with 16GA.
I bet your bench is just a tad on the far side of 100lbs?
EJWash
Old Jun 01, 2009, 03:15 PM
Las Vegas, NV
Joined Mar 2008
Around 125 lbs. Way overkill, but it was left over from a job so I'm using it.
Old Jun 01, 2009, 03:35 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
I'd use 3/4 iron clad if I got it for that price!
EJWash
Old Jun 01, 2009, 11:46 PM
Las Vegas, NV
Joined Mar 2008
Some sheeting and fitting around the engine. The fuselage looks a little bizarre at this stage.
Old Jun 02, 2009, 01:21 AM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Very nice craftsmanship.
EJWash
Old Jun 03, 2009, 12:15 AM
Las Vegas, NV
Joined Mar 2008
Thanks.
Finalized the fuel tank and plumbing. I also capped and sheeted the belly pan.
Need to build the tail so I can rig the controls before closing the top of the fuselage.
Old Jun 03, 2009, 11:41 AM
Resident giant scale guru
my c210's Avatar
Picayune, MS
Joined Oct 2007
seems like every build is waaaaaaaaay easier the second time around.
my c210 is offline Find More Posts by my c210
Old Jun 03, 2009, 10:49 PM
Las Vegas, NV
Joined Mar 2008
Old Jun 03, 2009, 10:59 PM
Las Vegas, NV
Joined Mar 2008
Built he tail feathers tonight.
I don't have full size plans (I'm cheap), so I enlarged the plans from the magazine. I only used them for a reference, they loose a lot of quality enlarged, but the overall outlines and sizes are useable. I cut all the stock using my tablesaw and miter gauge, so everything comes out square and proper. By ganging mirrored pieces together (tape) while cutting, both sides of the stab and elevator came out the same.
Leveling the parts:
Preparing the skins:
The pressure's on:
Old Jun 04, 2009, 01:36 PM
my c210's Avatar
Picayune, MS
Joined Oct 2007
Originally Posted by hammerd
I mean since you've already built one hots, the second one builds a lot faster, because you already know what to do.
Old Jun 04, 2009, 03:30 PM
Las Vegas, NV
Joined Mar 2008
This is my first "Hots".
Sold Morris Hot Hots Fun fly Long Kit rcgreaves Aircraft - Fuel - Airplanes (FS/W) 1 Nov 26, 2006 12:05 PM
For Sale RCM Hot Hots kit + Plan $100 shipped. rcgreaves Aircraft - Fuel - Airplanes (FS/W) 4 Oct 23, 2006 03:22 PM
Electric Hots Build Sail 'n Soar Sport Planes 37 Jul 30, 2005 06:13 PM
Hot Hots in RCM RCMODLR Electric Plane Talk 3 Dec 06, 2001 01:52 PM
