USA, PA, Telford
Joined Apr 2004
http://www.google.com/#hl=en&sugexp=...pw.r_qf.&cad=b
also, do a search for "hot wire" in this forum. Any craft store or railroad modeling store will have one off the shelf. |
Joined Mar 2012
PC power supply
I had an old PC laying around and robbed the PWR Supply from it. It works well with stainless single strand fishing leader wire. About like the thinnest guitar string. I use a drywall square clapped to the edgeof my work bench. the bench has a hole in it so I have a "bandsaw" like setup with a 20 inch bite. I use alligator clips to "energize" the wire. So with this set up I can hook it up to a nice 16 inch "bow" I made for it too. I used the internet to discover which wires are 5 volt and which are 12 volt on the pwr supp. Been using it for months. It's a bit slow at 26 inch span and very fast if I move the clips inside of about 15 inches span.
![]() Keep the span large enough to be slow and the current will be lower than a hotter fast cut with the span reduced. |
Actually a NiCd/NiMH battery charger does an excellent job as a hot wire cutter power supply. My friend and I have cut many wings using one to feed the hot wire. A LiPO charger would probably not work as those expect to see a certain voltage on the output, matching the number of cells programmed. There are even some multi-function battery chargers that have a specific mode for running a foam cutting wite...
Just us a charger for NiCd and start with the current set to about 1.5 amps. Depending on the wire you may need up to 3 amps but I doubt that any sane wire choice would need more than that. J.P. |
| Thread Tools | |
| Data Hot Wire Foam Cutter Calculator (UPDATED 7-31-2012) | vtdiy | The Builders Workshop | 90 | Apr 13, 2013 12:34 PM |
| Sold Hot-wire cutter variable power supply | jim breese | Aircraft - Sailplanes (FS/W) | 1 | Apr 13, 2012 12:48 AM |
| Question Drivers and Steppers for CNC Hot wire foam cutter | sscherin | CAD/CAM | 1 | Feb 27, 2012 03:08 PM |
