Old Oct 10, 2013, 05:57 AM
Joined May 2011
Programming the HK Afro ESC with the HK Afro USB programmer
@any one who can help
How do I use the Afro ESC programmer to flash AFRO ESC. I'd like to put the REVERSE firmware on a couple.
The documentation is a bit thin and I have only used FTDI with the KK Multicopter tool for other ESC types before. I am not even sure what this new programmer is but I suspect it is a USB Linker - I have no idea how to use it.
I could use a step by step walkthrough.
Regards
Alan
alan.powell is offline Find More Posts by alan.powell
Old Oct 10, 2013, 01:34 PM
Joined Oct 2013
i saw this video:
Turnigy USB Linker Tutorial (9 min 44 sec)
and it explains about turnigy usb flashing,
i also want to flash i2c adresses to the afro esc's using afro usb linker.
i found only one firmware file at https://code.google.com/p/afrodevices/wiki/AfroESC
but found no software or instructions
what software should i use?
davidvvv is offline Find More Posts by davidvvv
Old Oct 11, 2013, 04:12 AM
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Select the Turnigy USBlinker from the drop down menu of the kkflashtool.
I will add a Afro Programmer soon to the flashtool, but in the meantime you have to use this work-around.
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Oct 11, 2013, 10:02 AM
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Originally Posted by davidvvv View Post
i saw this video:
I think you only can flash the Afro ESC from HK with afro_nfet. It also has i2c. Then you have to set the i2c address in the tgy.asm and compile it. Repeate this for every ESC so that they have unique adresses.
Old Oct 13, 2013, 04:03 AM
Joined Oct 2013
how do i compile the asm file after editing it?
Old Oct 28, 2013, 10:35 PM
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
i saw this video:
https://www.youtube.com/watch?v=AsHBQLtQVuc
I thought the esc calibration was setting the max/min throttle for the tx/rx combination, that vid shows use of a servo tester for it. I get it would set the same for each and probably work but is this a recomended procedure?
microrcfiend is offline Find More Posts by microrcfiend
Old Dec 06, 2013, 02:50 PM
Joined May 2009
Any news?
fulvico is offline Find More Posts by fulvico
Old Dec 12, 2014, 11:31 AM
guyfawkes's Avatar
United Kingdom, England, Cheltenham
Joined Oct 2013
can you flash afro with an FTDI, which connections go wherE?
guyfawkes is online now Find More Posts by guyfawkes
Discussion Problem with programming HK ESC ceyal74 Power Systems 6 May 19, 2014 08:43 AM
Sold Castle Creations talon 90 esc with usb programmer $65 shipped obrieri Aircraft - Electric - Power Systems (FS/W) 1 Jul 21, 2013 09:36 PM
Help! Quadcopter settings for HK blue series 30a ESC with program card Power_user_EX Multirotor Talk 1 Apr 18, 2013 04:30 PM
For Sale Hifei 45a ESC with usb programmer $40 kennyhoc3 Aircraft - Electric - Power Systems (FS/W) 0 Jan 20, 2013 08:29 PM
For Sale NIP Hifei 45A esc with USB programmer $45 shipped kennyhoc3 Aircraft - Electric - Power Systems (FS/W) 0 Jan 16, 2013 01:15 AM
