Old Jul 29, 2013, 08:53 PM
kotori87's Avatar
Joined Dec 2006
A very small galleon
Ahoy there, folks! I am nearing completion on my latest project, the galleon Santa Maria in 1:144 scale. It began as a simple laser-cut shelf kit for a skeleton ship, but the project very quickly ballooned in its ambition. This little ship now sports sail control with a single servo, and a second servo for the rudder. Unlike my previous ships, I chose to add as much scale rigging as I could. I know that the rigging (and sail plan, and hull, and many other things) will make this ship handle poorly on the water, but I wanted to see how much strength the rigging could add. The result is some incredibly strong masts, even though I used sewing thread for all the rigging.
As I near the end of this project, I must decide what sort of keel I want to add. I have extremely little weight to work with, given that the largest ballast I can use is a AA battery. Any advice from fellow micro sailors on the subject of keels would be much appreciated.
kotori87 is offline Find More Posts by kotori87
Old Jul 30, 2013, 02:45 AM
Australia, TAS, Penguin
Joined Mar 2012
Originally Posted by kotori87 View Post
....As I near the end of this project, I must decide what sort of keel I want to add. I have extremely little weight to work with, given that the largest ballast I can use is a AA battery. Any advice from fellow micro sailors on the subject of keels would be much appreciated.
A single AA battery would weigh around 30 grams I would estimate. You can use a very light keel weight if you are prepared to add a lightweight, long (deep) keel fin with a very dense (lead) bulb on the bottom. Maybe the fin would be the length of the boat roughly, a bit like a footy.... The longer the fin, the less weight you need for the same righting moment.....
Hope this helps
mrpenguin is offline Find More Posts by mrpenguin
Old Aug 09, 2013, 09:16 AM
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Nice micro sailer !
whats her displacement ? did
My Micro sailships both had around 350g displacement so i was able to use a 100g keel on both. My Micro footy worked very well with only a 50g keel weight
meatbomber is offline Find More Posts by meatbomber
Discussion very small radio control of a gimbal vr360_pl Multirotor Talk 0 Jun 20, 2013 08:02 AM
Discussion Very small piece of metal stuck in very small hole - Help! dintmeister Micro Helis 4 May 08, 2013 09:48 PM
Discussion DARPA/University of Michigan - Very small 3-Axis/Non-GPS Navi Chip boiko Multirotor Talk 0 Apr 12, 2013 10:09 AM
Discussion Need advice- looking for very small shock absorber rjflory Car Talk 3 Mar 24, 2013 03:44 PM
Cool Very small glider Geagle Sailplane Talk 7 Feb 24, 2013 08:49 PM
