Old May 17, 2014, 05:35 PM
Dogdude is online now
Find More Posts by Dogdude
Joined Aug 2012
Boscam Storm FPV Goggles GS 922 with Diversity and Built in DVR
http://www.tecnic.co.uk/Boscam-Storm...-with-DVR.html
That's all the info I have
Anyone else know any more ?
Dogdude is online now Find More Posts by Dogdude
Old Jul 02, 2014, 08:19 AM
outbackkanga is offline
Find More Posts by outbackkanga
Joined Aug 2013
Looks like the ultimate goggle has Dual receiver diversity , DVR ,Headtracking and no horrible eye cups , it has the soft black Boscam full eye shroud which is extremly comfy to wear.
Binocular Goggle Display:
Field of View FOV = 30 degrees diagonal
Resolution = 854 x 480 (WVGA)
Brightness = 350cd/m2
DVR:
Video Resolution = 640 x 480 at 30fps
Memory Capacity = Micro SD Card
Wireless Receiver:
Frequency = 32 channels 5.8GHz
Sensitivity = -90 dBm +/- 1dBm
Antenna Connection = RP-SMA 50ohm
Video Standard = NTSC / PAL
A/V Input = 3.5mm 4 way, Video and Audio
DC Input = 5v 1 amp
Size = 172 x 88 x 60mm
outbackkanga is offline Find More Posts by outbackkanga
Old Jul 09, 2014, 11:11 AM
DeValk is offline
Find More Posts by DeValk
Mr. Electron
DeValk's Avatar
Chilliwack, Canada
Joined Jul 2003
I have a set of their original goggles and have been very happy with them. Can't wait for these to come out.
DeValk is offline Find More Posts by DeValk
Old Jul 10, 2014, 02:13 AM
Witoldc is offline
Find More Posts by Witoldc
Joined Feb 2014
I asked about the new Walkera googles recently that have similar specs to this set, but no info...
http://www.rcgroups.com/forums/showthread.php?t=2199380
Witoldc is offline Find More Posts by Witoldc
Old Oct 29, 2014, 10:05 PM
dhardjono is offline
Find More Posts by dhardjono
dhardjono's Avatar
Joined Jul 2013
I just order this goggle from Buddy/RC they have them in stock it was sent to me today i let you guy know how it is comparing to my skyzone.
dhardjono is offline Find More Posts by dhardjono
Old Oct 29, 2014, 11:42 PM
francischie is offline
Find More Posts by francischie
francischie's Avatar
United States, CA, Eastvale
Joined Dec 2013
Waiting for your review.
I'm still holding my purchase for domv2 because of this. I hope it has better LCD and lens than skyzone.
francischie is offline Find More Posts by francischie
Old Oct 30, 2014, 09:22 AM
Hobbyzone.Au is online now
Find More Posts by Hobbyzone.Au
More air time please!
Hobbyzone.Au's Avatar
Australia, VIC, Bayswater
Joined Sep 2013
I had the original boscam one from 3 years ago. Works well. . Only thing was that it didn't seal the light out well. Unless its just my face. . Lol
I just got my skyzones today. Wider view was weird at first. Look fwd to reviews!
Hobbyzone.Au is online now Find More Posts by Hobbyzone.Au
Old Oct 30, 2014, 10:50 AM
tjdeater is offline
Find More Posts by tjdeater
United States, MI, Kalamazoo
Joined Nov 2007
I received my GS922 goggles from BuddyRC yesterday. I like the fit (I wear progressive eye glasses) and the video quality seems decent (maybe not quite as good as my current Head Play goggles) but I'm having a number of issues with them. Below is the note I just sent to Boscam:
I received the GS922 goggles yesterday. When I turn them on the first time, they work great. However, after power-cycling the goggles the video quality degrades dramatically, rendering the goggles unusable. The only way to restore the video quality is to power off the goggles for 30 minutes or so, and then they work fine again (until the next power-cycle).
I don't think the problem is heat-related, because it happens even if I power-cycle the goggles after using them for just a few minutes. I've tested both 2s and 3s batteries and have had the same issue with both types of batteries.
It also doesn't matter which channel my video transmitter is using. I've tried all of the Band E channels on my TS353 transmitter and I have the same issue.
The goggles have also "crashed" on me a few times during auto channel-scan.
tjdeater is offline Find More Posts by tjdeater
Old Oct 31, 2014, 04:52 AM
Joined Aug 2012
Same here
Love my original AIO Boscam goggles, still use them now but due to my thin head they don't seal well at the sides, letting light in, and absolutely nothing sticks to that silicone rubber sheild to block out the light
Maybe I can fit some Skyzone eyecups to a set of Boscam goggles , best of all worlds for me then
Old Oct 31, 2014, 07:44 AM
_Milo_ is online now
Find More Posts by _Milo_
_Milo_'s Avatar
United States, ID, Pocatello
Joined Apr 2013
In the specs it shows 5V 1A for power supply, which made me think they had an internal battery. Whats the power input connection a USB??
_Milo_ is online now Find More Posts by _Milo_
Old Oct 31, 2014, 09:17 AM
tjdeater is offline
Joined Nov 2007
Yes, USB connected to a breakout box that accepts 2s or 3s battery input via balance connectors. The breakout box also provides AV in/out. You can see the breakout box in this image:
http://www.buddyrc.com/media/catalog..._gs922_4_1.jpg
Old Oct 31, 2014, 09:21 AM
tjdeater is offline
Joined Nov 2007
A quick update on my goggles: Buddy RC support has been very helpful and I just sent my goggles back for exchange today.
I was able to do one quick test flight with the goggles (forgot to put a card in the DVR though) and was quite pleased with the video quality. Much more comfortable than my ski-goggle-mounted Head Plays, and I think the video refresh rate is somewhat higher as well.
Old Oct 31, 2014, 09:53 AM
_Milo_'s Avatar
Joined Apr 2013
Excellent, I like BuddyRc, but never had an issue with anything I bought there, good to know they helped you out.
Old Oct 31, 2014, 12:21 PM
dhardjono's Avatar
Joined Jul 2013
I got mine i have no problems except some line scratch on lens but i don't see them wearing it what i am having problem is how do i get band 3 on freqency so far i love how it look the osd and fit on my face. The connector is male so i need adapter for my antenna .
Old Oct 31, 2014, 12:23 PM
dhardjono's Avatar
Joined Jul 2013
pictures
some pics
For Sale New 9" TFT LCD FPV Monitor Boscam RC901 In-built 5.8GHz Dual Switching Receiver & DVR uuustore1 FPV Equipment (FS/W) 6 May 25, 2014 06:58 PM
Sold 5" Display Mini DVR with built in 5.8Ghz receiver... Immersion/Fatshark compatible crd FPV Equipment (FS/W) 1 Feb 10, 2014 07:02 AM
Sold nib Boscam 5.8G Pocket FPV Ground Station with DVR ohsnap FPV Equipment (FS/W) 1 Nov 12, 2013 03:46 AM
Discussion fatshark goggles with built in video rx vcazan FPV Equipment 2 Oct 19, 2013 02:14 PM
