Old Feb 03, 2015, 11:48 AM
nioa is online now
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
That comes as a surprise to me too.
I have the Tacon 1.60 in a 9 foot plane with a APC 19x10E prop that is drawing almost 3400 watts on 10S. I want to prop down to about 2500 to 2700 watts. This is a crazy powerful motor!
Using this motor on 6S never occurred to me. Dangaras, what are your power readings with the Biela 18*10*3 on 6s?
nioa is online now Find More Posts by nioa
Old Feb 03, 2015, 11:51 AM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
When I look at the specs, the max efficient current is 75_Amps, so the trick is always to get the power, watts/lb using V*I. Then you have to worry about the KV and the prop size that's going to be spun. That's how one ends up with so many different ESCs and wire in the stock bin.
At the end of the day I go practical and measure the current, power and thrust on the ground also understanding that the props will unload in the air.
The specs have no low end data, just the max.
Dangaras is offline Find More Posts by Dangaras
Old Feb 03, 2015, 02:53 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
How do you know that the max efficient current is 75 amps?
ysolomon is offline Find More Posts by ysolomon
Old Feb 03, 2015, 05:47 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
It's in the data table on the hobbypartz website....
Model #: 96M608-Bigfoot-160-245Kv
Weight: 645g
Input Watts: 2700W
Outside Diameter 62.8mm
Lenght 64mm
No. of cells (lipo) 14
Max Efficiency 93%
Max Efficiency current 75
No Load Current(A) 7.4V 1.9
Internal Resistance: .0.03 ohms
Shaft Diameter 8 mm
Shaft Length 20 mm
KV (RPM/Volt) 245KV
Turns (for cars) Poles 8
Max Voltage 58
Wire Size 0.25
Bullet Connectors Yes
Bullet Connectors Size 4.0 mm
Old Feb 03, 2015, 06:09 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Sounds like 10S would be ideal, then.
Old Feb 03, 2015, 06:18 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Yeah, but....... I can't turn the 18*10*3 without cooking the ESCs and probably taking the motors way above the 75A..... What I've got now works and the props look good... I'll stay that way while I get used to her.
Old Feb 03, 2015, 07:21 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Oh, I wasn't suggesting you change anything. I was just fascinated by the wide range of operational envelope for this motor. I think I will start with the 12S, or even 11S setup on the 16x10x3 initially.
Old Feb 03, 2015, 08:30 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
No problem. I used a watts-up meter every time I "tested"my different configurations. The last 6S setup did concern me regarding the amount of current I was putting through the ESCs. Remember I run my packs in parallel so I can monitor the current to the entire setup.
Old Apr 21, 2015, 09:25 PM
rossaer is offline
Find More Posts by rossaer
Joined Aug 2008
ysolomon,
Just received the ESM F7F, and I'm starting to collect the needed parts. What motor/battery setup did you end up with? Still using the ESM landing gear?
Thanks fro any assistance.
al
rossaer is offline Find More Posts by rossaer
For Sale Big F7F tigercat - ESM WARBIRDS benjo Aircraft - Fuel - Airplanes (FS/W) 1 Mar 27, 2014 04:33 PM
Discussion Grumman F7F Tigercat (RBC kit) Build chinehamgeorge Electric Warbirds 30 Aug 10, 2011 07:30 AM
Discussion F7F Tigercat Build J Morgan Electric Warbirds 66 Sep 11, 2009 08:59 AM
Build Log B-25 Mitchell & F7F Tigercat Build philip noel Scale Kit/Scratch Built 163 Apr 09, 2008 06:56 AM
Bluecore F7F Tigercat Ready to fly!!! Bsouthwell Foamies (Kits) 20 Jun 30, 2002 02:52 AM
