Old Feb 18, 2015, 12:58 AM
Joined Sep 2013
Blade 130x losing power
hi fellow flyers
I've had my 130x for a month or so maybe 40 flights ive been loving it
then suddenly ive started losing that pop and raw power that i loved the motor gets very hot can holds fingers for 2seconds. i had a couple flights when the motor cut out during flight turned out to be low cell on battery checked motor temp it was ridiculously hot must have almost melted the plastic and u can smell a burning smell.
Power does seem to decrease towards the end of the flight.
any help would be great and could u guys please suggest some upgrade motors and where to buy ?
Simon88 is offline Find More Posts by Simon88
Old Feb 20, 2015, 11:20 PM
Beating air into submission!
bassman12350's Avatar
United States, CA, Twain Harte
Joined Feb 2014
Sorry you are experiencing this problem! The brushless motor for the 130X is a pretty decent motor, so going with an aftermarket BL motor might get you a little better performance, but probably not that much for the money. Is everything rotating freely (main rotor, tail rotor, etc.), or is there anything binding and thereby loading up the motor? Hair wrapped around the motor shaft or binding gears can load the motor to the point it will heat up significantly.
I'm not certain if an unbalanced battery or one with a weak cell will cause the motor to heat up that significantly - - a battery with a low charge just will not allow the motor to spool up enough to give decent power. And it is remotely possible you just simply have a bad motor.
Steve
bassman12350 is offline Find More Posts by bassman12350
Old Feb 21, 2015, 01:56 PM
Tucson, Az
Joined Feb 2007
Easy way get a fresh new battery and see if battery is problem. sometimes you get lucky and its easy fix. Bad charger or flying battery low kills batteries quickly. Motor and esc should hold up well.
dankar04 is online now Find More Posts by dankar04
Old Feb 24, 2015, 12:40 AM
Joined Sep 2013
everything moves freely got some battery on the way will give them ago
thxs
simon
Question Blade 130x vs Blade BO-105 130x addictedtoplanes Micro Helis 11 Oct 05, 2014 03:16 PM
Help! 130x losing tail sparatically illusion4021 Electric Heli Talk 1 Sep 26, 2014 05:19 PM
For Sale Microheli CNC 130X Tail Power Package for Blade 130X hstaniloff Aircraft - Electric - Helis (FS/W) 0 Jul 23, 2014 05:23 AM
Sold blade 130x lipo's thunder power 65c 325mah lipo's 25.00! neal the ace Aircraft - Electric - Helis (FS/W) 0 Jan 01, 2014 01:17 PM
Sold Blade 130x Micro Heli Head Power package $69 Helldiver Aircraft - Electric - Helis (FS/W) 0 Nov 09, 2013 07:25 PM
