Old Jan 10, 2015, 02:53 AM
Joined Dec 2014
Question
does quadcopter need identical motors?
One of my motors (Multistar MT2213 935kv) is slightly sticky and im planning to replace it. Obviously, idealy i would replace it with an identical motor, but i have spotted an EMAX motor, EMAX MT2213 935Kv. would this be a suitable replacement? or is their compatibility issues between brands?
I live in New Zealand, and can purchase the EMAX motors locally, and can find the Multistars at hobbyking only. Ive had about 30mins total fly time since i got the quad at x-mas so would prefer to buy locally rather than a minimum 2.5 week wait on shipping.
bopchong is offline Find More Posts by bopchong
Old Jan 10, 2015, 03:15 AM
BuffaloJustin's Avatar
United States, SC, Lexington
Joined May 2014
It depends on if they are truly identical or not. A lot of multistars are just green anodized versions of other brands motors but are direct copies otherwise. For example, I have a quad with two hengli W42-20 880kv motors and two Multistar 4220 880kv motors. The motors are exactly the same besides the fact that the henglis are black and the multistars are green, and therefore that quad flies fine despite me having used two "different" motors.
If the motors perform different, that's when you will have issues.
BuffaloJustin is offline Find More Posts by BuffaloJustin
Old Jan 10, 2015, 04:31 AM
Joined Dec 2014
Thanks heaps BuffaloJustin! i did think this was the case, as the two i was looking at have identical product names and just looked "re-branded". Thank you for the reassurance. Once again this forum pays off
Old Jan 10, 2015, 05:41 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
It's an interesting point about the effect of different motors: Does it not depend on how good the flight controller is? The flight controller keeps the copter level by adjusting the speed of the motors, and if one motor is behaving differently from the others (within reason) the flight controller will surely compensate by increasing or decreasing the throttle signal to that corner of the copter.
I'm new to multirotors, so I'm floating this to gain knowledge, not to contradict anyone
With my helis I can change the blade diameter on the tail, and the tail gyro (similar to one channel of a flight controller) will still compensate correctly because it only does what its sensor says is needed. I can even have the blades on the wrong way round, or the rotor going the wrong way, and the gyro can still work.
abenn is offline Find More Posts by abenn
Old Jan 10, 2015, 07:39 AM
Joined May 2014
Abenn, I believe you are correct, the key part being "to a point". The flight controller will compensate by sending a higher or lower throttle signal if a motor is producing more or less thrust then the mean.
Where this could bite you is when you are pushing the limits of a propulsion system; obviously a motor cannot be asked to give more than 100℅. And I would never do some craziness like put 4 different motors on the four corners of a quad
Old Jan 10, 2015, 07:44 AM
AMA 697691
Rochester, NY, USA
Joined Aug 2000
On my Tarot hex and quad, I use X and V series Sunnysky motors to help identify the back. The motor size and Kv are the same but the color, shaft size and t-prop mounting holes are different.
On other fun-fly quads, I have mixed motor and prop manufacturers, within reason, and they fly great!
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jan 10, 2015, 02:23 PM
Joined Jul 2004
At least that means the OP should have no problem replacing his Multistar motor with an Emax one that seems to have the same spec., even if it does turn out to be slightly different in some respect.
Discussion need help to identity this yacht hardrive Scale Boats 7 Sep 11, 2014 12:14 PM
Discussion Need help with identity Gooseoverland Beginner Training Area (Fuel) 2 Aug 09, 2014 10:46 PM
Discussion F450 motors and PHANTOM motors 100% identical? Biacman Multirotor Talk 0 Oct 27, 2013 04:21 PM
Discussion Does US law also protect identities of evil-doers? Marten Life, The Universe, and Politics 2 Mar 26, 2009 04:07 PM
Does the cc35 and cc45 have identical BECs? EddieNewYork Castle Creations 4 May 16, 2005 04:56 PM
