Old Mar 02, 2014, 01:57 PM
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Build Log
Mountain Models/Laser Arts Round2It
I have not seen a specific build log on the Mountain Models Round2It so I decided one should be accomplished. I have normally been doing build videos, but those take much longer and I'd like to knock out this build in short order.
I normally don't have two builds going at once but since I am still waiting on my servos to get here for my SA Soarstik, I figure now is a good as time as any.
Here is the details on the Round2It:
The Mountain Models Round2it! is a small electric sailplane model designed to bring back that relaxing feeling of catching small thermals in the local ball field. The 36 inch Round2it! is super easy to build and easy enough for a beginner to learn how to fly with some friendly help.
The Round2it! was designed using a state of the art 3D CAD package, to allow for exceptional interlocking parts design and fit. 3D design also allows us to provide clearer assembly images, without having to use photos.
The Round2it! is built from self-jigging interlocking laser cut balsa and plywood parts. It's like a 3D jigsaw puzzle with instructions. Although not needed for building, full size plans are included for reference. If the instructions are read before hand and followed during the build, the Round2it can be built up and ready to fly in only 2 to 4 evenings.
Without further ado, let's begin.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Murocflyer's Avatar
Joined Nov 2005
Component Choices and Steps For The Fuselage Build
Pictures are worth more than words so here is a photos build with descriptions. We'll see how this works out with RCG's new format. If it's too confusing I'll do it the old fashioned way.
Frank
Murocflyer's Avatar
Joined Nov 2005
Empennage and Wing Build
The pics show the empennage and wing build.
Found an unusual problem building the emepenage sections. Some of the little tabs broke off. They are usually a tight fit, but I have never had the tabs break off like this. I wonder if it's the balsa tree issue that people have been talking about?
Step 16 and 17 will come later. I only like to clean up balsa dust once during a build. I do have a great method to sand exact 45 degree bevels in my flight controls now. Will post pics later in the build.
Frank
Old Mar 02, 2014, 01:58 PM
Murocflyer's Avatar
Joined Nov 2005
The Final Touches
Here are the last few steps in the build process.
Step 37 note: I never have used this method before so I experimented with it. The heat shrink and CA works very well to hold the pushrods together. I had to cut them apart with my scalpel to separate them.
Frank
Old Mar 02, 2014, 06:02 PM
TScott1118's Avatar
United States, NM, Albuquerque
Joined Nov 2011
I'm watching! Looking great. Does the motor you chose have the same power as the recommended set-up?
Did anyone find a folding prop/spinner that will work on the R2I?.
TScott1118 is online now Find More Posts by TScott1118
Old Mar 02, 2014, 06:25 PM
Murocflyer's Avatar
Joined Nov 2005
That's a good question. I could not find the specs on the D1811-2000 anywhere so I just used the AUW of the plane to find the motor I chose. The T1804 weighs in at 14 grams but I am guessing can provide a lot more power than the 1811 (even though it doesn't need it but it will be fun nonetheless.
WRT folding prop, if your motor has a 3mm shaft then you can find the folding spinners here: http://www.headsuphobby.com/Folding-Props_c86.htm
I was going to use one as well, but decided against it due to the additional weight. I am hoping an ESC break will work well enough.
Frank
Old Mar 02, 2014, 09:25 PM
A&P Mechanic
T_arvis's Avatar
United States, NC, Charlotte
Joined Feb 2004
I love the Round2It! It is probably my most frequently flown plane recently. I set the ESC brake to activate and that seems to be plenty. I can glide with motor off for quite a while, so the excess drag doesn't seem to be an issue. One problem I have had, is the wings can warp, and just a little bit will effect the flight characteristics quite a bit more than I thought it would.
T_arvis is offline Find More Posts by T_arvis
Old Mar 03, 2014, 10:23 AM
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Frank
Looks like it is going together well as one would expect from a MM kit.
Need to get started on mine.
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Brian Allen is offline Find More Posts by Brian Allen
Old Mar 03, 2014, 01:03 PM
Condescending Pedant
Joined Aug 2013
D1811-2000
I found the specs for the motor right on MM's website. Link follows:
http://www.mountainmodels.com/produc...roducts_id=636
Just going by weight, it looks like yours should be more powerful. 15G vs 10 for the 1811.
Mike Dubovsky is online now Find More Posts by Mike Dubovsky
Old Mar 03, 2014, 06:59 PM
Murocflyer's Avatar
Joined Nov 2005
Thanks Brian, too bad that's about it for the week though. Hard to believe you can glue a plane together in just one day. I never expected to get that much done.
I'll be sure to watch for wing warp as mentioned above.
Mike,
FYI
The weight of a motor is not considered "specs". Specs look like this:
Stator Diameter ................................... 22.0 mm (0.866 in)
Stator Thickness .................................... 8.0 mm (0.315 in)
No. of Stator Arms .................................................. ..... 12
No. of Magnet Poles .................................................. .... 14
Motor Wind .................................................. 26 Turn Delta
Motor Kv .................................................. 1550 RPM / Volt
No-Load Current (Io) .......................... 0.53 Amps @ 8 Volts
Motor Resistance (Rm) Per Phase ..................... 0.150 Ohms
Motor Resistance (Rm) Phase to Phase ............. 0.100 Ohms
Max Continuous Current ...................................... 15 Amps
Max Continuous Power on 3S Li-Po ...................... 165 Watts
Weight .............................................. 46.5 Grams (1.64 oz)
Outside Diameter .................................. 27.7 mm (1.091 in)
Shaft Diameter ..................................... 3.17 mm (0.125 in)
Body Length ......................................... 24.0 mm (0.945 in)
Overall Shaft Length .............................. 38.0 mm (1.496 in)
and this:
http://innov8tivedesigns.com/Cobra/C...8-26_Specs.htm
Frank
Old Mar 03, 2014, 07:05 PM
Joined Aug 2013
Yes, I know what motor specs are. I was using the 15g and 10g to differentiate which motor I was speaking of. The post I made included a link to the motor that is specified by Mountain Models for this plane. The link is to their web page where many of the specs for that motor are included. I do not know, nor do I care to look up, the specs of the motor the OP has purchased to use on this model. All I was saying is that since the motor is larger than the specified motor that it would likely work for this airplane.
Old Mar 03, 2014, 07:13 PM
Murocflyer's Avatar
Joined Nov 2005
No worries Mike, just trying to help you out when you said this:
I Just wanted to make sure that you knew that motor specs are more than just the weight of a motor. There are a lot of newcomers that read these threads and they could misunderstand that like I did because a heavier motor does not always equal more power. That is where the specs really need to be researched.
Frank
Old Mar 03, 2014, 10:25 PM
TScott1118's Avatar
Joined Nov 2011
Mike,
FYI
and this:
Frank
I wish I know what all of that meant. I only worry about watts, amps and kv and weight.
Old Mar 03, 2014, 10:40 PM
Joined Aug 2013
Well some of the specs are physical dimensions, so that you will know if it will fit in your airplane. Some of the specs like phase resistance are electrical parameters of the motor. You would want to know some of these if you were putting the motor information into a motor simulator, so that the program would be able to more accurately predict motor performance. Some of the specs just tell us how the motor is built, like number of poles and number of magnets. I guess some of the motor simulators use this and tell you how many steps the motor takes in one revolution, but you really don't need to know that to predict amp load or power consumed. My feeling on it is you can never have too much information, just too little.
Old Mar 03, 2014, 10:41 PM
Murocflyer's Avatar
Joined Nov 2005
Yea, me too.
But, if you ever do decide that you want to learn more, download these podcasts.
http://www.allthingsthatfly.com/
I download a bunch at a time and then listen to them only way back and forth from work. You would be surprised how much you can learn just from listening to them. Best thing is, if you hear something you didn't quire understand, you can "rewind" it and play that part again.
Frank
Build Log Mountain Models Round2it - new builder TyTy29 Balsa Builders 39 Apr 16, 2014 06:57 PM
Build Log #1 Model Airplane Building Clinic >> Mountain Models/Laser Arts Switchback<< Murocflyer Balsa Builders 21 Nov 26, 2012 07:41 PM
Discussion Mountain Models/Laser Arts Appreciation Thread Murocflyer Parkflyers 175 Aug 01, 2010 01:13 AM
Discussion Mountain Models/Laser Arts P-51 Flying Low Electric Warbirds 3 Jun 18, 2007 02:53 PM
Wanted Mountain Models/Laser Arts Cessna 180 BD Flyer Aircraft - Electric - Airplanes (FS/W) 1 Mar 07, 2007 08:13 AM
