Old Feb 20, 2015, 07:44 PM
Jet-Set !
xenon20's Avatar
United Kingdom, Clevedon
Joined Dec 2013
Think I'm going to go with this
xenon20 is offline Find More Posts by xenon20
Old Feb 21, 2015, 09:31 AM
Joined Dec 2008
That looks good . Did you ever get your retracts working properly ?
pencon is offline Find More Posts by pencon
Old Feb 21, 2015, 09:47 AM
Jet-Set !
xenon20's Avatar
Joined Dec 2013
The faulty ones went back and were replaced with a new set from HK.
To be honest I still don't have a lot of confidence in the cheap retracts , and if they are not up to the job then i'm gonna be screwed as the mountings were designed around them.
I don't think there are any other options which have a low enough profile for the wing section, but if anyone finds anything which is 24mm depth or less then please share details
Which retracts do you have / are you going to use pencon ?
P
Old Feb 21, 2015, 04:54 PM
Joined Dec 2008
I don't have any yet , which is why I was asking . I know - cheap retracts , I have a durafly vampire and so the second time now , one of the retracts stopped working . Also have a dynam meteor , none of the retracts worked , had to buy eflites . I wonder if the Freewing Eurofighter retracts would be any good ?
Old Feb 22, 2015, 01:29 PM
Joined Dec 2008
D_fast , I recall you saying the bigger version was actually for 100 mm fan . Do you think a 105 would be too big for the inlets ? Still deciding on a fan and eyeballing up the new HSD unit ..
Old Feb 23, 2015, 07:27 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
the bigger version is just 2x 50mm
but the internal ducting area ruling curved it back to a 90mm.
Although im pretty sure she could breathe easily enough for a 100 or a 105
while looking at Xenon20 edf issues ,and the plans it looks like i forget to scale back the edf unit wall thickness after the increase in scale from 50mm to 90mm.
sorry about that.
D_FAST is offline Find More Posts by D_FAST
Old Feb 24, 2015, 06:53 PM
Jet-Set !
xenon20's Avatar
Joined Dec 2013
No bother dude.
Can I ask if your thrust reverser slots at the rear of your fuse were functional or were they blocked off by your thrust tube?
Cheers
Old Feb 24, 2015, 08:37 PM
TEAM HILLBILLY
buildcrashrepair's Avatar
United States, KS, Leawood
Joined Jul 2013
I think you should put a servo actuated thrust reverser inside the thrust tube so you can back up
buildcrashrepair is online now Find More Posts by buildcrashrepair
Old Feb 25, 2015, 08:35 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Originally Posted by xenon20 View Post
No bother dude.
Cheers
sorry for the late response.
I have a 1/4" gap around it to let air flow through the reverser and around the thrust tube and exist out the back, to help eliminate drag
Old Feb 25, 2015, 06:05 PM
Jet-Set !
xenon20's Avatar
Joined Dec 2013
...Meanwhile, back on planet earth....
Ok cool, I will probably put the thrust tube support ring further back. Have you had a chance to paint yours yet D_Fast ? Are you going to ?
P
SAAB VIGGEN KITS or PLANS Sluf7 Fuel Jet Talk 14 Jan 04, 2012 10:30 AM
Saab Viggen 37 Sluf7 Electric Ducted Fan Jet Talk 11 Oct 20, 2008 08:45 AM
Saab J-37 Viggen FoxBAT138 Electric Ducted Fan Jet Talk 42 Nov 30, 2005 11:10 PM
SAAB JAS Gripen & JA 37 Viggen Built up from Plans anywhere Sluf7 Electric Ducted Fan Jet Talk 2 Jun 25, 2004 07:11 AM
Scorpio saab viggen and fantex andrea Electric Ducted Fan Jet Talk 44 Nov 04, 2003 12:55 PM
