Old Mar 26, 2015, 11:37 AM
Poland, Masovian Voivodeship, Warsaw
Joined Mar 2006
Hello all!
My PNF version (no stabiliser) arrived today. I've got strange 5 -wire connectors on servos named HK-02B. Tried to connect simply first 3 wires (black, red & white in standard order), but after connecting battery (TX-RX binded, TX switched on), both servos goes extreme positions and after trying to move the Ail/Ele stick, the ESC starts strange loude noise, while throttle stick works fine.
Anybody had similar problem ? I've tried to look for it but cannot find proper keywords
Update:
Tried to connect both other remaining wires as signal (yellow and brown, one at a time ), with just the same result. What's going on with these servos ?!?
Edit:
It looks like this servos can be operated by original stabiliser ONLY. They are probably "toy servos" without electronics, to be operated by AIO receiver/stabiliser/servo-controler boards, so selling this kind of PNF set w/out stabiliser makes no sense at all. Servos need immediate exchange to normal ones...
kinemax is offline Find More Posts by kinemax
Old Yesterday, 03:29 AM
Joined Mar 2006
Now I know That's manufacturers mistake, so if you have same story, you shall replace servos with normal ones (HK 3,7g works fine in my case) and ask for servo value refund (which I received within 2 days).
Generally plane flies very nicely with stabiliser (I've put Lemon stabilised RX), but is difficult to manage without it.
When I changed the prop to stiff 4,75x4,75, model is faster and quieter (!!!), but looks like original ESC haven't survivied bigger prop
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1034 Jan 24, 2015 03:52 PM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s stuart warne Electric Warbirds 12 Jun 14, 2011 02:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 10:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 01, 2010 11:15 PM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 02:47 PM
