Old Dec 13, 2012, 01:14 PM
BJM-Maxx is offline
Find More Posts by BJM-Maxx
BJM-Maxx's Avatar
Joined Sep 2007
Question
CC-BEC radiated emissions issue
I have a multicopter hexa that I fly using a DJI Flamewheel 550 frame ESCs and motors. The control board is an Ardupilot APM 2.5. I use a CC-BEC to power the flight controller. This has worked just fine for a while now. I decided to make a tidier set up and protect all the electronics (not the ESCs, they are mounted on the arms) inside a waterproof plastic container. In doing so I have the BEC closer to the ardupilot. Test flights gave me a ton of twitching in my roll axis. I assumed it was a connection problem but simply moving BEC about 2 inches solved the problem.
I assume the internal switching frequency of the BEC was coupling radiatively into the Ardupilot since at no time did I change the wiring. Is this generally a problem for this BEC and is there a simple shielding arrangement I could rig up. The only thing I have handy is aluminum tape.
In the flamewheel, the BEC is not back to being between the two center plates at one edge. The Ardupilot is on top of the top plate in the middle.
BJM-Maxx is offline Find More Posts by BJM-Maxx
Sold CC PHOENIX ICE 100 & CC BEC 10amp choopi Aircraft - Electric - Power Systems (FS/W) 1 Feb 24, 2012 02:10 PM
Question CC BEC into Bind Plug issue oceanexplorer Beginner Training Area (Aircraft-Electric) 1 Nov 05, 2011 08:02 PM
Discussion CC BEC and Motor Issue - Help AJ5000 Power Systems 5 Sep 29, 2011 12:45 AM
Question CC BEC issues? Lithuanian Flyer Power Systems 10 Nov 24, 2007 03:49 PM
CC 60 and 80...glitch or BEC issue. ChuckD Castle Creations 11 Aug 23, 2005 05:15 AM
