Old Jul 12, 2014, 02:50 PM
Joined Nov 2011
Wood Plank
After having my spar-less foam wing fold using a 300 watt motor I decide to build a balsa plank. It turned out well, but did not fly as nice as my foam planks. The balsa plank only had 2" elevons and weighed a little more then the foam. I think 3 inch elevons would help the flying, but landings are a little too hot. So I decided to add a spar to a foam wing at the trailing edge because I did not want it on the face of the wing. I am sad the plank does not fly as well because it hold its shape over time. After about a 100 foam wing flights they start deforming and fly weird.
I may try a balsa delta. I think the delta will fly better. I find that my wings that have a further back CG will glide better and land slower. Plank vs delta with same weight and same surface area, the plank will not float in for a landing like the delta.
Does the CG affect the glide on well balanced wings with the same weight and surface area, but different rates of sweep ? Is it the more aft CG that lends to a better glide or is it the wing sweep ?
JerseyDevil is offline Find More Posts by JerseyDevil
Old Jul 12, 2014, 04:55 PM
Joined Apr 2013
Generally: Given the same wing area and weight, the one with the lower aspect ratio will be "easier" to fly (and will appear to glide "nicer"), but will have a lower glide ratio.
The nice thing about sweep is that you get the same effect that dihedral gives you (some roll stability) without having to actually have any dihedral.
Pure, rectangular planks are generally more twitchy than something with some sweep.
And yes, a more aft CG will mean less reflex required, which will mean less drag - so the glide ratio will be better. But there's only so far you can go back. Other factors like wing loading, aspect ratio and drag causing structures (like excessive winglets or protruding cameras) are the key contributors to glide ratio.
nuteman is online now Find More Posts by nuteman
Latest blog entry: My youtube channel
Old Jul 12, 2014, 05:27 PM
Joined Nov 2011
Thanks nuteman. I am sure if I built super lite the plank would behave better during the landings, but it always seems windy where I fly so a lite plane may be not so good either.
Build Log 60" Plank, PW106, high AR, solid wood AndreasMergner Slope 81 Nov 01, 2007 06:23 PM
Discussion What wood for planking breakwater Sailboats 14 Mar 19, 2007 02:02 AM
Discussion wood plank Fly'n fish Flying Wings 1 Oct 28, 2006 03:23 PM
source of plank wood bnhorton Scale Boats 12 Oct 22, 2005 02:07 PM
Wood for planking woodmantexas Scale Boats 14 Sep 07, 2005 09:24 AM
