Old Aug 02, 2013, 09:55 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
Build Log
Bell 429 Super Scale detailed build log
700 Size Super Scale Bell 429 Air Zermatt
Building the new 700 size Bell 429 Super Scale from RC Aerodyne.
It's going to be about the same size as my AS350 Super Scale.
Bell 429 Specs:
Body length: 1650mm
Length incl. rotors: 1920mm
Width: 355mm
Height: 480mm
Main rotor diameter: 1560mm
Main blade length: 700mm
Tail rotor diameter: 280mm
Tail blade length: 105mm
So let the fun begin. You should of seen my mail lady carry this down the driveway!
Just like my AS350 this thing is packed for war. Everything is glued and taped in secure.
As usual the paint scheme and fiberglass quality is Excellent! This box is PACKED!
It includes full scale mechanics, four bladed head and tail rotor blades, full interior from instrument panel, seating, down to joysticks and pedals.
Body Parts
Scale Mechanics
Interior Parts
Accessories
Lets take a closer look at the fuselage
Top doghouse cover removed
Side and sliding cargo door open
Battery compartment
Mechanics compartment
Scale Mechanics
Mechanics housing
Main rotor head
Tail rotor
Test fitting the mechanics
Build session #1
I always start by installing the skids so that I have a working platform.
Manual has you starting with interior first but I jumped to getting the mechanics test fitted, tail section aligned, and drilled and glued in tail section mounting blocks
Once tail section was mounted and secure I could move onto horizontal and vertical fin installation
I also glued on the running boards. I moved onto water transfer decals next so I re-installed top dog house cover
Water Transfer Decal Time!
Before
After!
Instrument panel, foot pedals, joysticks, collective levers, and pilot seats installed
This thing is Big! Not 1/6 scale big, but works for me!
crmodels is offline Find More Posts by crmodels
Old Aug 02, 2013, 09:59 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
Body lines are pretty nice, tons of body rivets, the doors don't fit perfectly closed but I'd bet if I sanded down some paint they would close better. The painted main and tail blades are a nice touch and can't wait to see them spooled up. I really, really enjoyed that the skids were finally Air Zermatt white... Had to paint them on both my AS350's.
Bell 429 and AS350 Super Scales
Here are some Interior detail pics
Here are some Exterior detail pics
Here are all electronics needed to complete the build!
Using:
PhoenixTech 500kv motor
Edge HV120 ESC
CC BEC
THOR 45c Lipos
Naza H FBL Unit
Spektrum AR8000 with sat
Outrage BL 9180's on cyclic
Outrage BL9188 on tail
Sexy Outrage BL cyclic servos
The Outrage servos were to deep, the wires hit the metal mechs so I had to move the holes up
Servos horns and links installed
Motor, ESC, BEC, RX, and Naza mounted. Next will be all the soldering and starting the programming!
Test fit to see how she will look
All soldering is done and mechs re-test fitted.
Old Aug 02, 2013, 10:33 PM
Ado
Meow?
Ado's Avatar
Brisbane Intl, Australia
Joined Sep 2001
Looks awesome. How easy are the batteries to put in and take out?
Ado is offline Find More Posts by Ado
Old Aug 02, 2013, 10:39 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
I'm still building it so really haven't had to take them out or put them in.
You simply slide the back center console back to unlock the three front seats, lift up and out to get to the packs.
Old Aug 03, 2013, 10:58 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
Snuck a few hours in tonight while my daughter was sleeping.
Tail case, pushrod, boom braces, and tail servo installed
Close look at some of the electronics
Setting up the Naza H
Still have to adjust all links to proper length for servos and head
Old Aug 25, 2013, 04:28 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
Ok boys. Sorry this build is dragging on, that thing called life gets in the way. With my Lil Hailey and crazy 50hr work weeks not much time for building. Plus this is my prime demo/funfly season.
So any who, after doing a weekend of demos with my big AS350 Super Scale it resparked my drive! Got in about an hours worth on it today after I got home from the funfly.
My Lil Hailey
Mechanics are in, wires are soldered, head/tail installed
Next is linkages and set up pitch
Old Aug 25, 2013, 08:09 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
I see a maiden in my sites!!!
Head installed
Rotors installed
Electronics strapped
Just waiting on a nice day and Big nerves...
Old Sep 22, 2013, 06:13 PM
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Sub'd
Rudderman98 is offline Find More Posts by Rudderman98
Old Sep 22, 2013, 06:37 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
Hopefully I will have an update soon. Took it to the parking lot for the maiden and the ESC went up in smoke. CC is sending me a replacement this week and hope to try the maiden again...!
Thank you for subscribing
Old Oct 05, 2013, 04:16 PM
Smoke em ' If ya got em
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Sub.... LQQking forward to vid.....Good Gawd that's BIG !!!!
( Been a long time since I have done a scale..( thinking of doing a 500 with chaos mechanics )
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Oct 05, 2013, 04:28 PM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
ESC going back in very shortly! Finishing up a bunch of reviews and getting the replacement ESC back into the 450 Pro! Can't wait it get this beast airborne!
Old Oct 06, 2013, 10:15 AM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
While you guys wait for me to get back to the 429 here are some cool shots Jenni Orebaugh took at our Heli Jamboree last month.
Old Oct 09, 2013, 05:06 PM
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Looking very nice, look forward to reading a flight report.
topgearuk is offline Find More Posts by topgearuk
Old Oct 13, 2013, 09:47 AM
Scratch Builder
AlexanderB's Avatar
Braunschweig, Germany
Joined Sep 2006
Subscribed!
I am very interested in this Helicopter. Can't wait to hear your maiden report.
Cheers
Alexander
AlexanderB is offline Find More Posts by AlexanderB
Old Oct 13, 2013, 11:13 AM
Chris Reibert #78
crmodels's Avatar
Joined Dec 2008
I am very anxious to finish mine. Really want to see her fly!
Here is my same model someone built in another country. Going to be sweet!
Bell 429 Superscale Air Zermatt (7 min 54 sec)
Build Log Passer 1.8 PNP Electric detailed build log Rfriedman Electric Sailplanes 2 Aug 18, 2013 07:08 PM
Careful! Roban Bell 429 VS. Smartmodel Bell 429 Mikarro Scale Helicopters 18 Mar 06, 2013 09:55 AM
Discussion RC Aerodyne Bell 429 Scale Cockpit catcat Scale Helicopters 0 Dec 18, 2012 03:00 AM
Discussion bell 429 scale fuselage finally release by A2pro ben429 Scale Helicopters 0 Apr 24, 2011 08:21 AM
