Old Oct 31, 2012, 06:04 AM
interplanet's Avatar
Sheboygan Falls, WI
Joined Nov 2006
HK "Trendy" Full House 2250mm Glider
HK dropped a new glider today. A full house 88 inch winspang glider. Labeled as an entry level F5J plane. Looks fantastic for the price to me.
Features:
Epoxy-glass and Carbon fuselage
V-tail design
Built up, 3 piece, bolt on wing
Alloy outer panel wing joiners
Aileron, flap and v-tail control surfaces
Transparent Oracover covering
Low drag, clean, efficient design
Suitable for both 28mm Outrunner and Inrunner brushless power systems
Spec:
Material: Epoxy/Carbon fuselage; Balsa wings
Wingspan: 2250mm
Length: 1000mm
Airfoil: S4083(Mod)
Spinner: 30mm diameter, suits 4.0mm shaft
Flying Weight: 800g - 1000g
http://www.hobbyking.com/hobbyking/s...50mm_ARF_.html
interplanet is offline Find More Posts by interplanet
Old Oct 31, 2012, 07:09 AM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
I just saw that on HK... Dang, I want one
JimNM is offline Find More Posts by JimNM
Old Oct 31, 2012, 09:07 AM
Joined Sep 2007
To install 28 size outrunner is sure painful as hell. If anyone have good idea how to install outrunner motor in such narrow n deep nose pls post. Thks
Regards,
Edwin.K
edwin3162 is offline Find More Posts by edwin3162
Old Oct 31, 2012, 09:30 AM
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
Get some threaded rod or a really long 3mm bolt. Push through from the firewall, engage a few threads into the mounting holes on the motor, gently extract the threaded rod - pulling the motor snug against the firewall and tighten a correctly sized bolt in one of the other holes, then remove the over-length piece and insert the other bolt(s).
MAKE SURE YOU DO NOT OVER PENETRATE and short out the windings
Old Oct 31, 2012, 11:44 AM
Joined Sep 2007
Hi Jim, Thks for great tips.
Regards,
Edwin.K
Old Oct 31, 2012, 11:46 AM
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
I seem to recall that tip mentioned using a swash plate arm (?) or something similar from a helicopter... can't quite find it in the databanks.
Old Oct 31, 2012, 12:02 PM
Joined Apr 2012
Dang! That might just upset my plans but I'm not real keen on the idea of either being a beta tester on a new item or ordering planes from the international warehouse. If there are a few good reviews and/or it comes to the U.S. warehouse? I think I'll have to get one.
(NOTE: I have a Specter 1800 from HK and love it. But? I think they either lied about the weight or they mistakenly listed the weight without battery. I wouldn't be the least bit surprised if the Trendy is a bit heavier than they claim.)
I'll second Jim's idea for installing a motor in a tight nose but have also been able to use a hemostat locked on to the back of a motor to get it lined up. I also like to install motors and stuff before I install the tail feathers.
peterlngh is offline Find More Posts by peterlngh
Old Oct 31, 2012, 01:34 PM
TM1
Joined Jan 2012
Looks good.
I like the one long flap concept. it will take 1 less servo but will need a stronger one.
The flap servo can be inside the fuse making a cleaner wing. Nice touch.
Also, I'll bet 90% of the pilots will cut a cockpit in the fuse sooner or later.
TM1 is offline Find More Posts by TM1
Old Oct 31, 2012, 03:08 PM
Dragons, Windmills. All Same.
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Looks interesting. The price could be nice, dependent on shipping cost and especially if it arrives in one piece.
The design does remind me of, of, of................oh, a Sky Sergio.
jcstalls is offline Find More Posts by jcstalls
Old Oct 31, 2012, 03:35 PM
Joined Apr 2012
It looks like shipping is around $45.00, jcstalls. Not prohibitive IMO. That risk of damage is what concerns me though it should be a straight forward fix if the wing spars, glass fuse, and tail boom are intact. Hopefully they ship them to the U.S. warehouse before I'm ready to purchase next year's sailplane!
Old Oct 31, 2012, 03:52 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
I'm fighting the BUY IT voice in my head. I just got my hands on an Elegant 700 a month ago... had I known this was on the way I could have saved 50% on that purchase
Oh well, I'll give a few days. Right now it looks really nice -
Old Oct 31, 2012, 04:06 PM
Joined Apr 2012
Me too, Jim. I even have that extra KDA 22-20L staring me in the face and it would be perfect for this one. We'll have to see if the approaching winter can enhance my patience.
Old Oct 31, 2012, 04:11 PM
jcstalls's Avatar
Joined May 2002
$45.00 is not bad for shipping. I will at least wait for several flying with personal comments and also USA warehouse option.
Old Oct 31, 2012, 06:12 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
You and I think much alike Peter. The 11x6 on 3s would make a good combo for this one.
Man, why did I have to get that 300.00 glider last month??
Old Oct 31, 2012, 06:28 PM
jcstalls's Avatar
Joined May 2002
The Elegant 700 ship does look nice, probably built much better and especially if one ever has wind.
The Sky Sergio or type is a nice ship for light air, but did not do as well in wind.
Found Older full house glider gdjsky01 Aircraft - Sailplanes (FS/W) 6 Oct 15, 2012 11:39 PM
Discussion Hitec Optic 6 Sport as a full house glider radio aeajr Sailplane Talk 12 Oct 06, 2012 11:26 PM
Discussion Stalling a 2m full house glider, best recovery methods? SoarWest Electric Sailplanes 31 Jul 26, 2012 03:07 PM
Discussion 11X and full-house motor gliders in Glider Mode. lornecherry Sailplane Talk 1 Jul 18, 2011 07:57 PM
Large electric LMR full-house glider ShredAir Electric Sailplanes 0 May 15, 2003 09:22 PM
