Old Aug 02, 2015, 06:46 AM
W0WG is offline
Find More Posts by W0WG
Landings are not optional!
United States, VA, Chesapeake
Joined Jul 2012
Question
What do LiPo battery IR readings signify ?
I just discovered that my charger can display the "IR" value of individual cells, as well as the total battery IR.
Is that information useful to me? If so, how do I use it?
TIA for your responses.
W0WG is offline Find More Posts by W0WG
Old Aug 02, 2015, 06:51 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
It is a measure of how much of the voltage is lost across the internal resistance of the cells when you draw current. The smaller the IR, the better the battery and the less internal heat is generated within the battery.
Rodney is offline Find More Posts by Rodney
Old Aug 02, 2015, 09:29 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
WOWG,
IR can be useful in determining the health of your battery. When you get a new battery measure and record the IR of each cell. Then periodically measure the IR and compare the numbers to your original record. As the battery ages the IR will increase.
Unfortunately not all devices that measure IR will give the same reading for a given battery so I cannot tell you what a good number would be for your battery.
The measurement will be in milliohms and for a new battery in good condition the reading will probably be in the range of 2 to 10 milliohms
Point of interest: Anytime you mention a device it is good practice to be specific and even include a link to the device if possible. i.e. what charger are you using?
May I also suggest you read this: http://www.tjinguytech.com/charging-how-tos
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Aug 02, 2015, 08:38 PM
yurstruly is offline
Find More Posts by yurstruly
Chicago, USA and Manila, Philippines
Joined May 2007
check this thread about IR .. also there's a spreadsheet avail at this thread for the IR of the battery you purchase to give the health , true C rating (based on IR) and estimated life expectancy of your lipos..l
http://www.rcgroups.com/forums/showthread.php?t=1577989
http://www.rcgroups.com/forums/showt...1#post20484169
http://www.rcgroups.com/forums/showp...99&postcount=5
yurstruly is offline Find More Posts by yurstruly
Old Aug 03, 2015, 09:06 AM
W0WG is offline
Joined Jul 2012
Gents,
Thank you for the info and links - I will give them a look.
My charger is a "Hobby People" TAZR. It was received as part of a recently purchased "package deal". I don't have a manual and discovered the IR check screen by accident while exploring what the buttons do.
I am a new R/C Airplane 'pilot' and purchased two batteries with a Hobby Zone Super Cub S. They are both eFlite 3S/1300mAh/20C. One has never been used (only charged once) and the other has one flight and then re-charged.
Readings:
1. 13, 16, 16 and total battery IR=45 (the unused one)
2. 14, 21, 27 and total battery IR=62 (the one with one cycle).
It looks like the charger simply adds the three cell values to come up with the total battery IR ?
I will start a log and check the IR after each flight to see if there is a trend or change.
Thanks for your help,
Discussion What brand lipo batteries do you use that you are happy with? Mg73nd Multirotor Power Systems 38 Jul 05, 2015 06:12 PM
Discussion What do you do when your bored, have no decent batteries and are on week six of waiti Tsheets Micro Helis 23 Jun 03, 2015 01:23 PM
Discussion At What IR Do I Throw Out Lipo Batteries? WhiteCloud Batteries and Chargers 8 Oct 07, 2014 05:25 PM
Discussion Giles Meter IR/ESR Readings - What Are Good & Bad Ones? itsme2 Batteries and Chargers 5 Jan 18, 2014 08:46 AM
Question What do the lights on my Spektrum transmitter signify? w1indse7 Electric Plane Talk 7 Mar 23, 2012 12:30 PM
