Old Mar 23, 2015, 03:24 AM
sshireto is offline
Find More Posts by sshireto
Joined Jan 2015
Help!
HKPilot 2.7 crashed my AXN
Hello,
Yesterday I flew FPV with my AXN equipped with HKPilot 2.7.
I tested the RTL first and it worked, came home and circled around. On the next flight I took off, flew a bit and then I wanted to sit down and fix my chair so I put it on RTL, it started coming home and I wasnt looking at the plane, and then I heard it crash behind me, simply nose dived down to the ground..
Any suggestions for what happened?
sshireto is offline Find More Posts by sshireto
Old Mar 23, 2015, 03:52 AM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Download the logs and post them over at DIY Drones for someone to disect
Dogdude is offline Find More Posts by Dogdude
Old Mar 23, 2015, 09:13 AM
PeeMax is offline
Find More Posts by PeeMax
Registered Loser
PeeMax's Avatar
Iceland, VestmannaeyjabŠr
Joined Aug 2011
Was everything set up correctly?
Did you set the correct magnetic declination, waited for the gps to lock before you took off and so on?
PeeMax is offline Find More Posts by PeeMax
Old Mar 24, 2015, 06:18 AM
sshireto is offline
Joined Jan 2015
Do you have connect through the USB for that? Cause all I get is gibberish on the Terminal.
I never calibrated the compass, I don't why I guess I forgot. You think that can cause that?
The GPS was locked though.
Old Mar 24, 2015, 05:56 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
If you didn't calibrate the compass how did you expect it to work at all? I'm surprised it even returned home the first time.
The APM is a very capable but very complex piece of kit that has a lot of features and requires a fair bit of setting up. If you can skip the compass calibration and wonder if it might cause your plane to crash, then I would suggest you do not use it again until you study the entire manual.... TWICE
Here: http://plane.ardupilot.com/
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
Old Mar 25, 2015, 12:13 AM
sshireto is offline
Joined Jan 2015
Cheers,
Geoff
Actually, I didn't calibrate because of some video saying it can setup itself while in the air, and it also say you can do that here:
http://plane.ardupilot.com/wiki/ardu...ime-apm-setup/
But ofc I'll do it now, thanks for the help.
Discussion Buddy Codes for HKPilot 2.7 (APM 2.6), Turnigy Plush 30A, CF Props, etc. RexSmith HobbyKing 0 Mar 06, 2015 06:54 AM
Discussion HKPilot Mega 2.7.2 - Programming the ATMEGA32U2 szakacs Multirotor Electronics 0 Dec 29, 2014 06:37 PM
Discussion HKPilot Mega 2.7 scottie52 Multirotor Electronics 3 Oct 15, 2014 10:37 AM
Discussion RTFhawk 2.4.3 or HKPilot Mega 2.7 FlyingPancake Multirotor Talk 1 Aug 19, 2014 05:00 AM
