Old Jan 02, 2015, 06:01 PM
BWRIGHT is offline
Find More Posts by BWRIGHT
United States, NY, St James
Joined Jun 2002
tug weight
Anyone have an idea of what are the approximate un-ballasted weights of the invader or darby or pono tugs are?
BWRIGHT is offline Find More Posts by BWRIGHT
Old Jan 02, 2015, 07:13 PM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
They are in the neighborhood of 25-35lbs. Depending on how you build it, number of functional options, and motor size/gear box.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Jan 02, 2015, 09:44 PM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
My Pono weighs about 40 lbs. unballasted and almost 60 lbs. with the batteries in...
The last Invader that I had my hands on weighed almost 50 lbs. without batteries and 70 lbs. fully loaded...
capntroy is offline Find More Posts by capntroy
Old Jan 02, 2015, 09:56 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
A "Mr. Darby" weighs 60 - 62 lbs, at the "LIGHT displacement" waterline, otherwise, 65+ lbs. There is a good reason, some of us do not have boats like those listed above!
CaptCB is offline Find More Posts by CaptCB
Old Jan 03, 2015, 11:43 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
My Darby is just about 22 pounds with no ballast or battery.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Jan 03, 2015, 06:10 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
My Darby when ballasted comes in at around 48 pounds. My invader will be at about 80 lbs when ballasted. The Ponos I have seen seem to be around the 40 lb ballasted weight. Empty or ballasted, they can get heavy real fast.
keith S is offline Find More Posts by keith S
Old Jan 04, 2015, 11:54 AM
MASSAILOR is offline
Find More Posts by MASSAILOR
Joined Jan 2014
My invader seems to get heavier by the day when I am home. Hopefully in a few weeks it will be float tested to waterline and I'll get you a total weight then.
MASSAILOR is offline Find More Posts by MASSAILOR
Old Jan 05, 2015, 12:19 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
What waterline are you going for? As with tugs, how much fuel and other gear is on board, makes a BIG difference, on how deep it sits in the water.
Old Jan 05, 2015, 07:46 AM
BWRIGHT is offline
Joined Jun 2002
I was looking for the empty weight of the model. I dont mind making 2 trips up the basement stairs to the car. 1 trip with the battery and as much removable ballast as possible in a depot pail and next trip with the boat. The back isnt what it used to be.
Old Jan 05, 2015, 09:43 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
I understand that problem, that is why, the 12'', under 4 lbs, Truckable Towboat, was conceived. I can go run a boat, or attend a contest, without having to lift or carry anything that weighs very much.
Discussion Dumas Brooklyn Tug Boat - Customized Similar to Jersey City Tug HelloScott Scale Boats 15 Jun 01, 2015 07:14 AM
Discussion Methods of adding 'weight' at the front without adding any weight to the front RC Aerobat Modeling Science 27 Oct 14, 2014 08:53 AM
Found aquacraft atlantic tug. any shape gutted etc or similar tug takevin Boats (FS/W) 3 Mar 02, 2014 07:47 PM
Discussion Maule tug/Dle 30cc suggestions on glider size and weights to tow? egall232 Scale Sailplanes 7 Dec 30, 2010 03:24 PM
Question Rotor Tug, Regular Ole' Tug, Harbor Tug. What Is A Tractor Tug? boat_builder Dock Talk 45 Apr 17, 2008 07:48 PM
