Old Dec 05, 2013, 07:27 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
HobbyKing Extra 330 1500mm
Anybody got one of these?
They were on sale at a very good price so I ordered one!
I'm no 3D pilot but it is something that I plan to work on if this will suit...
Tony
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Phase 6 sport
Old Dec 06, 2013, 04:24 PM
scottc39 is offline
Find More Posts by scottc39
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
are you talking about the balsa plug and fly unit, I had looked that one over a ton but was afraid of shipping damage.
scottc39 is offline Find More Posts by scottc39
Old Dec 07, 2013, 02:59 AM
BMFA 190658
Joined Mar 2007
That's the one!
So far I've only heard that it could do with a better elevator servo.
You've got me worried now about shipping...
Old Dec 08, 2013, 07:22 PM
Flying Fiz is offline
Find More Posts by Flying Fiz
Flying Fiz's Avatar
Sydney Australia
Joined Dec 2009
Did you read the reviews of it prior to buying? They are usually a fairly good indication of the quality and flyability of the planes.
Flying Fiz is offline Find More Posts by Flying Fiz
Old Dec 09, 2013, 02:36 AM
abcxuemues is offline
Find More Posts by abcxuemues
Joined Dec 2013
abcxuemues is offline Find More Posts by abcxuemues
Old Dec 09, 2013, 03:31 AM
BMFA 190658
Joined Mar 2007
Yeah, that's where I saw that they suggested a better elevator servo.
Just wondered if anyone on here had one...
Old Dec 11, 2013, 06:16 AM
rosnik is offline
Find More Posts by rosnik
1000MIGLIA City - Italy
rosnik's Avatar
Joined Mar 2012
Are you telling about this Extra330????????
"Extra 330 Balsa Plug and Fly 1500mm for 6s w Motor ESC MG Servo"
http://hobbyking.com/hobbyking/store..._MG_Servo.html
Today GLS will delivery mine at home. :-)
rosnik is offline Find More Posts by rosnik
Old Dec 11, 2013, 07:14 AM
BMFA 190658
Joined Mar 2007
That's the one!
I have a couple of 6S 5000mAh and one 6S 4000mAh that I use in my Helis, been meaning to get a 6S plane for ages...
Let us know how you get on please!
Tony
Old Dec 12, 2013, 06:16 AM
rosnik is offline
rosnik's Avatar
Joined Mar 2012
I received today, pictures coming....
Old Dec 12, 2013, 08:15 AM
BMFA 190658
Joined Mar 2007
And video!
Tony
Old Dec 13, 2013, 02:16 PM
rosnik is offline
rosnik's Avatar
Joined Mar 2012
On 3D forum there is one tread ( now closed ) were sone not informed guy,
say that this 330Sc from HK is one 3DHS clone.
like William Shakespeare say:
Much Ado About Nothing
This is NOT a copy of 3DHS plane.
If you simply see pictures you will understand that's completely different project plane!
I'm attuned that people easily spend words and injury simply following one ghost.
I get pictures you can easily get paragon yourself.
Old Dec 29, 2013, 04:49 AM
BMFA 190658
Joined Mar 2007
I got mine a while back now, but only just taken it to the club and opened the box.
It all looks good, well apart from a bit of loose covering at the base of the fin that I can easily fix if I must, but I was surprised that there were absolutely no instructions!
Putting it together should be easy enough. The dual elevator servos will be a first for me so I may use an Elevon mix on a flight mode switch. It will be nice to setup each side independently with endpoint and subtrim. I think I read that someone said the elevator servo would be best swapped, I'm thinking by saying servo instead of servos this seems to imply theirs only had one, but this could easily have been a typo...
No mention of CoG either! I may start at 1/3 wing chord and flight test it there.
I was going to look at fixing the elevator halves together to work off one servo and use the other rear mounted servo for the rudder. I really want yo avoid using pull-pull if I can. On the other hand using both servos for the elevator will give some redundancy if one fails, plus it may well be less likely to fail in the first place only working half the surface.
Any thoughts?
Tony
Old Dec 30, 2013, 02:45 PM
BMFA 190658
Joined Mar 2007
I've found a manual for this online:
HobbyKing Extra 330 manual
CoG 100mm
Plenty of other good stuff too!
I'll build mine soon.
Tony
Old Dec 31, 2013, 09:57 AM
rosnik is offline
rosnik's Avatar
Joined Mar 2012
CoG 100mm
Tony
Thank you Tony!
Old Dec 31, 2013, 11:31 AM
BMFA 190658
Joined Mar 2007
Have you built yours yet rosnik?
Any top tips?
The instructions say to glue the wings on but I want to avoid this if it's easy enough...
Tony
For Sale Great Planes Giant 38% Extra 330S ARF Piano_man49 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 04, 2014 11:31 PM
Sold Great Planes Extra 330S ARF NIB nero1156 Aircraft - Electric - Airplanes (FS/W) 2 Dec 04, 2013 10:18 PM
Sold Great Planes Extra 330S ARF NIB nero1156 Aircraft - Electric - Airplanes (FS/W) 1 Nov 26, 2013 06:14 PM
For Sale 3DHS 57" Extra 330 Airframe Only - LPU - $100 6L6Amp Aircraft - Electric - Airplanes (FS/W) 7 Nov 23, 2013 07:07 AM
