Old Mar 06, 2015, 05:17 PM
SmokeDogg is online now
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
I was on about the 30th flight on her, maybe more. It was the first flight of that morning. I had just taken off and was headed downwind for a photo op. When the wing came off I was at half throttle coming out of about a 10 degree left bank turn. I had not even opened it up yet that day.
I was always gentle in the turns at full speed as you never know if the wing will hold up. Turns out it had an expiration date anyways...
I have the same setup in the new H9 P-47d and the H9 BF-109. They have held up awesome with tons of flights!
SmokeDogg is online now Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Old Mar 08, 2015, 12:38 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Power 90 w/ 8S on 17x12 APC prop
I am posting my Castle ESC for folks to review. I am very happy with this setup, and you can see the battery and prop are matched very well. I am running 8S 3600 mah for 7.5 min flights, and using a Mr RC Sound with two TT-25 speakers under the cowl for ballast.
The attachment is a doc file, and the Castle viewer will load it if you select *.* file types.
tclaridge is offline Find More Posts by tclaridge
Old Mar 10, 2015, 06:16 PM
mrfirkin is online now
Find More Posts by mrfirkin
Oh, Ho, Ho, It's Magic!
mrfirkin's Avatar
Australia, VIC, Southbank
Joined Apr 2004
Rudder & Elevator Throw ?
If you go by the manual and use their servo arm setup, you have bugger all throw on your rud/elev.
I ended up using longer servo arms (they almost touch) to get the recommended throws.
Trouble is, it affects the alignment of the pushrods somewhat .
Did anyone else encounter this?
I may have to enlarge the servo cutouts so I can move the servos further apart.
mrfirkin is online now Find More Posts by mrfirkin
Old Mar 14, 2015, 08:32 PM
Scamp73 is offline
Find More Posts by Scamp73
United States, NC, Autryville
Joined Jan 2012
Originally Posted by SmokeDogg View Post
My right wing failed where the wing tube holder was in the ribs. The last rib only had one piece of Balsa and no ply like the left wing. The center section of the wing where it attached to the fuse was still attached to the fuse.
Just be careful as they do have a terminal velocity. lol
I am building another as I really did love flying it!
Are those the stock wing screws on the bottom side of the wing under the scoop? Appears they are allen wrench heads? I am still trying to find out how to get my wings off as I cannot get this bird in my car.
Scamp73 is offline Find More Posts by Scamp73
Old Mar 15, 2015, 03:37 PM
RCBlackSheep is offline
Find More Posts by RCBlackSheep
I'd Rather Be Flying
RCBlackSheep's Avatar
Stockton CA
Joined Feb 2009
Yes the allen head bolts are under the scoop
RCBlackSheep is offline Find More Posts by RCBlackSheep
Old Mar 15, 2015, 03:57 PM
SmokeDogg's Avatar
Joined Jul 2009
Yep, they work good too.
Old Mar 23, 2015, 09:26 PM
Scamp73 is offline
Joined Jan 2012
Power 160 10s
Finally got my Maiden flight in and it was awesome :-)
Old Mar 24, 2015, 02:20 AM
Stockton CA
Joined Feb 2009
Congrats Scamp! Post some video if you get some.
Old Mar 24, 2015, 07:20 AM
Scamp73 is offline
Joined Jan 2012
Will try and get one. I was at the field by myself for the maiden.
Discussion NEW Top Flite P-51 Mustang 60 ARF MUTID Fuel Warbirds 10 May 11, 2009 10:29 PM
Discussion Hangar-9 P-51 Mustang PTS ARF dfruehwald Electric Warbirds 8 Mar 21, 2009 09:55 PM
Discussion Hangar 9 P-51 Mustang PTS ARF - Recommendations sandydr Fuel Warbirds 27 May 27, 2008 09:43 AM
Sold Hangar 9 P-51 Mustang PTS FUSELAGE ARF rcfunhouse Aircraft - Fuel - Airplanes (FS/W) 0 Mar 30, 2008 12:57 AM
For Sale F/S Hangar 9 P-51 Mustang 60 size electrified (Airframe Only) LOCAL PICKUP Aobid Aircraft - Electric - Airplanes (FS/W) 12 Jun 24, 2006 08:07 PM
