Old Nov 20, 2012, 11:12 PM
LCx
Joined Jun 2012
New Product
Alware Streak 800 :D which strong and stable Hexacopter
Specifications:
Kit:
-Diagonal Wheelbase: 800mm
-Carbon Arm Boom Length: 281mm
-Carbon Arm Boom Weight: 23.6g
-Motor Mounting Frame Size: Φ13x22-34mm(Shaft x Screw Diagonal Distance)
-System Platform Frame Dimension: 105x66x42mm (LxWxH)
-Bipod Landing Gear Dimension:
188mm(Top Width) x 466mm(Lower Width) x 348mm(Height)
-Landing Skid Pipe: Φ10x420mm
-Bipod Landing Gear Weight: 136g
-Total Kit Weight: 1110g (Without Electronics & Props)
-Total Kit Weight With Motors & Props: 2330g
Propeller:
-Manufacturer: APC PROPELLERS in USA
-Size: 144.7 Inch
-Root Hole Diameter: 5-6mm
-Center hub thickness: 6mm
-Weight: 25.3g/pcs
Motor:
-Model: Alware Multicopter Brushless Motor 3515-15
-KV value: 400KV
-Stator Diameter: Φ35mm
-Stator Length: 15mm
-Propellwe Mount Diameter: 6mm
-Motor Dimension: Φ42.5x35mm
-Weight: 178g (with 3.5mm Bullet Connectors and Prop Mount)
-Input voltage: 22.2V 6S LiPo Battery
-Max continuous current: 35A(180sec)
-Max output power: 750W(180sec)
-Internal resistance: 175mOHM
-Recommended ESC: HobbyWing 40A/ 60A
Speed Controller/ ESC:
-Current: 40A or Above
-Voltage: 22.2V 6S LiPo
-Largest Dimension: 30x80x25mm (WxLxH)
-Recommended ESC: HobbyWing 40A ESC(for 22.2V 6S Lipo)
Flying Parameters:
-Max. Takeoff Weight: 7.0Kg
-Max. PayLoad Weight: 2.3Kg (With 12600mAh Lipo-1.7Kg)
-Power Battery: 9000-15000mAh 22.2V 6S LiPo (Minimum 15C)
-Hover Power Consumption: 1300W (Takeoff Weight 6.5Kg)
-Max. Hover Time: 15 min (With 12600 mAh & 6.5Kg Takeoff Weight)
Manual about Streak 800 Click here.
Are you interested in this kit ?
http://www.flying-hobby.com/shop/str...o-p-10770.html
LCx is offline Find More Posts by LCx
Discussion ALware Streak 800 Hexacopter Seller Thread John_AL Multirotor Talk 71 Nov 19, 2013 09:44 PM
Discussion Which Mini Quad for Newbee? (Most Stable) gur75 Mini Multirotors 14 Dec 09, 2012 10:34 PM
Discussion which is the most stable heli PROACE Beginner Training Area (Heli-Electric) 15 Jun 25, 2012 10:36 AM
Build Log Simple strong economic hexacopter in carbon and glassfiber frame jack-frank Multirotor Talk 13 Jan 02, 2012 03:58 PM
Question Which servo for alware cam stand babanan Multirotor Talk 12 May 22, 2011 02:17 PM
