Old Feb 13, 2007, 11:01 AM
justy g's Avatar
Hong Kong
Joined Jan 2007
jr pcm9x
Hi guys
I am looking at buying a jr pcm9x radio here in Hong Kong but it is in mode 1 (throttle on right)
How easy is it to change a jr pcm9x radio from mode 1 to mode2?
Justy
justy g is offline Find More Posts by justy g
Old Feb 13, 2007, 11:33 AM
United Kingdom, Slough
Joined Aug 2003
Depends if it is ES spec. If the NET code is NET-N239ES then the system has stick mode enabled, if it is an FS or HS, then it doesn't have Stick Mode enabled.
theaton56 is offline Find More Posts by theaton56
Old Feb 13, 2007, 08:29 PM
justy g's Avatar
Hong Kong
Joined Jan 2007
Thanks for your reply mac man.
What does es,fs and hs mean?
Does it have these printed on a stamp on the tx?
Justy
Old Feb 13, 2007, 08:37 PM
Joined Aug 2003
I believe that ES is Export Spec, FS is Fixed Wing Spec & HS is Heli Spec. It relates to how the switches & labels are positioned. Usually the FS & HS variants do NOT have user Stick Mode change facilities.
The NET code is located on the switch label usually to the right of the JR top plate ( see http://www.kenney.eclipse.co.uk/NewW...mages/2610.jpg as an example)
Synthesizer module for JR PCM9X Dsim Radios 13 Nov 19, 2004 09:56 AM
jr pcm9x arno123 Radios 6 Sep 28, 2004 07:58 AM
Help! JR PCM9X Manual Robert May Radios 1 Jan 30, 2004 05:42 PM
