Old Today, 07:51 AM
Joined Jan 2015
Build Log
First quad advice QAV 250
so I've been wanting to build and own a custom QAV 250 and I have collected a list of parts, all I need is for someone more skilled in building quads to check that it will work. Thanks.
The list:
3S LiPo Battery: http://pages.ebay.com/link/?nav=item...d=151415904328 $16.49 + $10.91 (Postage)
LiPo Charger: http://pages.ebay.com/link/?nav=item...d=140931443719 $7.50 + $1.99 (Postage)
Mystery 20A ESC: http://www.dx.com/p/mystery-bec-esc-...0a-6-12v-13021 $18.23 (for 1) $72.92 (for 4)
Frame: http://www.getfpv.com/qav250-mini-fpv-quadcopter.html $167.38
FlySky Remote: http://www.dx.com/p/flysky-fs-t6-2-4...-8-x-aa-178448 $93.89
Mystery Motors: http://www.dx.com/p/mystery-a2208-12...ss-motor-35707 $15.21 (for 1) $60.84 (for 4)
Acro Naze32 Flight Controller: http://boltrc.com/index.php?route=pr...product_id=605 $29.98
dan14941 is offline Find More Posts by dan14941
Old Today, 08:49 AM
Joined Jan 2015
Hi, I am doing the same, and need the same kind of advice, but I haven't had a response at all.
check my list maybe you will find things that could be of good use for your build too.
http://www.rcgroups.com/forums/showthread.php?t=2336570
Multirotor Go is online now Find More Posts by Multirotor Go
Old Today, 08:59 AM
Joined Jan 2015
If I had to buy a new remote I would buy a devo 7e, it seems you can hack it and make it work with a big list of quadcopters and make it compatible with many recivers.
it cost like $55 on banggood.
and google : devo 7e deviation and look for the deviation web page too, here also you can find info.
And if you could spend a litle more money on the charger I would go with one that you could charge at list 6 lipo at the same time.
Look for imax b6 parallel charging. I just added a parallel charging board to use with the imax b6, you can find cheap ones like $8 on hobbking. Just choose one with compatible plug for the batteries you are buying.
A good charger and a good remote are investment for the log run. If you buy devo 7e you are saving some bucks that you can use to upgrade the charger you have in your list. But research first yourself to see if you find I am correct.
Help! First build 250 fpv c.f. frame need advice Multirotor Go Scratchbuilt Multirotors 2 Yesterday 01:14 PM
Question QAV 250 DIY Mini Quad Wobbling macjax Mini Multirotors 13 Nov 10, 2014 04:28 PM
Discussion QAV 250 Vs. Blackout Mini H Quad hjstaples Mini Multirotors 0 Aug 20, 2014 02:45 PM
News QAV 250 mini fpv-quad from Lumenier Matt Gunn FPV Talk 10 Dec 23, 2013 02:32 AM
