Old Jan 23, 2015, 06:14 PM
Noob
Joined Jan 2015
Help!
Parkzone Sport Cub (the red one)
I must say, I love this model!
But, I have run into a snag, one which days of research have yet to remedy: I need a larger prop and cannot figure out how to select the right one. I installed the float kit on the sport cub, which calls for a larger prop. The one that came with the kit had the wrong size hole. Actually, the hole is WAY too small. It cannot be drilled out either as there would not be enough material left to mount the prop. My online searches for an appropriate prop have left me frustrated and prop-less. I believe the kit calls for a 10x5.
What do I do?
Kodiak338 is offline Find More Posts by Kodiak338
Old Jan 24, 2015, 10:42 AM
Bush Flyer
William Wolfen's Avatar
Joined Jan 2015
The prop and directions are designed for the older super cub lp. The sport cub s2 should be fine with the stock prop. If you wish to go to a larger one, you will also need a better speed controller as the stock one is only rated for 18 amps. The electric plane talk section of the forum has a 500+ page thread dedicated to the plane if you want more information. Good luck and keep on enjoying that sport cub!
William Wolfen is offline Find More Posts by William Wolfen
Old Jan 24, 2015, 10:47 AM
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
Tons of info on this plane here (huge thread)
http://www.rcgroups.com/forums/showthread.php?t=2139067
As far as the prop goes, i have ran 6 different props on mine.
The best prop by far, is an APC 10x7 SF.
http://www3.towerhobbies.com/cgi-bin...?&I=LXNG57&P=7
You will need to change the ESC to a 30 amp.
I feel they should have included a better ESC to begin with.
My ParkZone Artizan uses the exact same motor & it came with a 30amp ESC
This is the ESC i used on my Sport Cub:
http://www.headsuphobby.com/Sky-Powe...-BEC-H-100.htm
The 10x7 SF prop fits the stock adapter & needs no modification on the spinner.
The only thing necc. is to add a washer to the front of the prop, because the prop hub is thinner than the stock prop.
Clive66 is online now Find More Posts by Clive66
Old Jan 25, 2015, 06:00 PM
Noob
Joined Jan 2015
Thank you gentlemen! I will do as advised!
Download Parkzone sport cub spk file bimmerland Sport Planes 0 Oct 17, 2014 09:29 AM
Discussion Parkzone Sport Cub mods Ftsdeploy Electric Plane Talk 2 Oct 07, 2014 09:25 AM
Sold Parkzone Super Cub / Sport Cub Floats Air Candy Aircraft - Electric - Airplanes (FS/W) 3 Jul 02, 2014 04:21 PM
Found Parkzone Sport Cub or MPX Fun Cub Foam boy Aircraft - Electric - Airplanes (FS/W) 3 May 08, 2014 05:15 PM
