Old Apr 30, 2010, 02:06 PM
Joined Mar 2010
The plastic top end of the antenna fell off of my one month old DX5e
transmitter.
The DX5E seems to work fine with just the wire sticking up.
Do I send it back under warranty to have it fixed?
If I do that then I can't fly my plane until it comes back.
Do I just keep using it the way it is?
Anybody else have this kind of problem and how did you fix it?
thanks,
mrdb is offline Find More Posts by mrdb
Old Apr 30, 2010, 02:40 PM
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
I did. I took apart (destructively) an old wireless LAN antenna to get to the top rubber bit (destroyed the bottom connector bit but learned a lot about them) and used it on the DX5e. Fitted on perfectly... seems they are an industry standard. The tiny lugs (one each side) used to secure and hinge the top cover piece are really, REALLY small. I recommend you do everything on a sheet of white paper.
I also didn't want the hassle or expense of sending the TX back.
Worth trying, and worked fine for me.
Toppers is offline Find More Posts by Toppers
Old Apr 30, 2010, 04:16 PM
Joined Mar 2010
thanks for the idea... I think it's fixed....
For Sale DX5E - broken Antenna plastic - $30 Shpd UNGN Aircraft - General - Radio Equipment (FS/W) 2 Jan 21, 2010 08:08 PM
Discussion antenna fell off my GWS Rx rcnutt Power Systems 21 Apr 27, 2009 11:35 AM
End Cap Fell Off Motor - Feigao 20mm 21T Short Can Buzz_Man Power Systems 5 Jun 05, 2005 06:06 PM
T4D front end fell off!!!!!!!!!!!! RORO 3D Flying 18 Feb 15, 2005 01:58 PM
