Joined Feb 2007
Completed witha 1500mAh 3s it weighs 16oz exactly the same as the Skyray but as predicted the longer duct reduces the static thrust by 1 oz to 10oz.
The maiden flight was a success in some ways - it flew quite nicely - but a disaster in others - the elevons proved completely inadequate with virtually no roll power at all to the extend I was only just about able to keep it straight. The maiden flight finished in the next field. Clearly ailerons were required. Not easy with such a thin wing and with everything built permanently in! The scale ailerons cut out. The wing is so thin that even a 3.7g micro servo has to lie flush with the surface. Running the servo wires was a bit of a nightmare requiring many holes to be made in the skin. I was not happy with the tailplane spar so I took the opportunity to install a short but bigger diameter one with a spring loaded 'pip' to retain the tailplane. With the new servo wires installed the holes were simply filled with inserted patches. A bit of lightweight filler and paint and you can't even see the joins! Completed. The aileron servos have added 1/2oz to the total weight. For a ducted 'fan' it is still very light for its size so it flies slowly however unlike fans a ducted prop continues to develop significant thrust at reduced power so even with the small battery it has a considerable 10 minute+ endurance. It even glides quite well! An edited video of its first two flights.
The only real problems with it are being so light it needs really calm weather and the very low set tailplane is easily damaged in the belly landing. |
| Thread Tools | |
| New Product 700mm WS Hawker Hurricane | anj4de | Electric Warbirds | 17 | Aug 23, 2012 03:45 PM |
| Build Log 45" Hawker Hurricane | playaviation | Foamies (Scratchbuilt) | 38 | May 06, 2012 10:42 AM |
| Build Log Hawker Hunter | bidule | Scratchbuilt EDFs | 13 | Mar 27, 2012 06:59 AM |
| Sold E-flite hawker hurricane 25e bnf | hi2nr | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 06, 2012 08:21 AM |
| Discussion 63" Hawker Typhoon | Warbird@home | Giant Electric Planes | 6 | Mar 01, 2012 02:38 AM |
