Old Feb 23, 2012, 12:02 PM
robert14 is offline
Find More Posts by robert14
robert14's Avatar
Emmen, Netherlands
Joined Aug 2008
Servo holes in bagged wings
Hi guys.
I have a question to all the people who build their own bagged wings. How do you make the holes in the wing for the servo's? I used to just bag the wing and then cut out the bottem skin.. Scratch out all the foam and glue in the servo. On my last wing I tried something else.
Before bagging I already cut out the hole (square) for the servo. I wrapped the piece of foam that comes out of the wing in clear packing tape. Then I waxed the tape and put it back in.
After bagging you can see where the peice of foam is. Cut it open at the bottem skin and you can just take out the piece of foam that is wrapped in tape. In this way I get a nice clear servobay in the wing.
But is this the easyest way or are there different ways to do it?
this is how it looks like after taking out the foam:
robert14 is offline Find More Posts by robert14
Old Feb 23, 2012, 12:24 PM
DLGjunkyard is offline
Find More Posts by DLGjunkyard
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
I have thought about doing that but what I find is when I router the pocket out after bagging the wing I end up leaving a very thin wedge of foam at the bottom of the pocket. With your method you must have a looser fit. The small wedge at least keeps the servo from rocking.
I just made this little jig and use my dremal to cut out the pocket. It takes literly 2 minutes and I get a very tight fitting hole.
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Feb 23, 2012, 12:31 PM
bwill6 is online now
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
How do you cover the servo holes after the install when you router out the holes? Do you just put tape over it? I like having the skin to put back over the servo because it looks better.
Brandon
bwill6 is online now Find More Posts by bwill6
Old Feb 23, 2012, 12:39 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Most will cut the skin off with an exacto knife and peel it away from the foam before routing.
I do not have a template but that is what I do:
1. Using a pin, verify there is sufficient depth for servo.
2. use knife to cut perimeter and then peel off skin from foam.
3. using dremel, 'route' a test piece of foam to verify depth. Then route wing.
4. clean up corners with knife.
Fly2High is offline Find More Posts by Fly2High
Old Feb 23, 2012, 12:45 PM
Joined Apr 2010
Brandon
The most recent one I did I made another jig that was about 2mm wider and only routered out the skin and then the servo is taped with double sided tape to that cover plate for a flush fit.There is a shelf for the cover plate to sit on.
I will get a picture up loaded shortly
Old Feb 23, 2012, 01:15 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
Some do the peeling off of the skin so that they can re-stick it to the top surface to reinforce it.
Old Feb 23, 2012, 01:25 PM
robert14 is offline
robert14's Avatar
Emmen, Netherlands
Joined Aug 2008
I always take out all the skin, all the way to the top skin. If the servo is thinner then the wing I'll glue in some balsa to strengthen it. I used the dremel before but with thin wings I'm always scared that i cut the top skin
Old Feb 23, 2012, 01:34 PM
Joined Apr 2010
Here are a few pics. Kind of hard to see the ledge or lip I referred to with all the kevlar fuzz etc
This one had the servo removed so you can see where it removed some of the wedge of foam from the base.
Old Feb 23, 2012, 05:49 PM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
$0.02
My method using a router...
gopherhunter is offline Find More Posts by gopherhunter
Old Feb 24, 2012, 06:08 AM
Marty B is offline
Find More Posts by Marty B
Marty B's Avatar
UK, Isle of Anglesey, Holyhead
Joined Jun 2010
I love that idea of the lip! I wish I had thought of that before I did my wing!
Marty B is offline Find More Posts by Marty B
Question Bagged 2M Carbon mystery wings target Thermal 0 Oct 05, 2011 07:41 PM
Discussion Warped Flaperons On Bagged Disser Wings BavarianCharles Hand Launch 17 Jul 19, 2011 04:19 AM
Sold Fred Sage bagged CR Contender Wings CR_Aircraft Aircraft - Sailplanes (FS/W) 4 Jun 27, 2011 09:29 AM
For Sale Shrike Carbon bagged winchdoc toothpick wings lilmaf Aircraft - Sailplanes (FS/W) 0 Mar 25, 2011 10:11 PM
