Old Oct 23, 2013, 09:48 AM
Germany, BW, Stuttgart
Joined Apr 2012
Build Log
Little Red Dragon
My latest project is a park Flyer, a small red dragon.
Built from Depron 6 mm, with CFRP bars.
The wing as a flat plate, without KFM.
The hull with head, neck and abdomen is from 6 mm Depron, inside are battery, receiver and motor Controller, they have enough space.
The dragon is controlled by the delta tail with 2 servos.
Wingspan 900 mm, length 700 mm, weight 270 g
Hacker A10-13L motor, prop GWS 7035, YGE 12 A, Lipo 3S850.
I´ll add some pictures of the construction period.
When the wind is weaker, I will make the maiden flight the next days.
When the dragon flies well, then I´ll upload a short video on Youtube and publish the link here.
Hape
Hapewin is offline Find More Posts by Hapewin
Old Oct 23, 2013, 10:15 AM
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Well done!
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Oct 23, 2013, 03:28 PM
United States, UT, Herriman
Joined Jan 2012
Looks good. I've been wanting a dragon to fly around....
ttabbal is online now Find More Posts by ttabbal
Old Oct 23, 2013, 05:49 PM
Flying Models for 51 Years!
Sixter's Avatar
Georgia, United States
Joined Oct 2002
I like Dragons, this one is very nice!
Sixter is offline Find More Posts by Sixter
Old Oct 23, 2013, 09:38 PM
Osprey Engineer's Avatar
Philadelphia, PA
Joined Oct 2005
I like dragons and have one on my build list (one day). Found a book of paper dragons from Klutz that I scanned and blew up to make a foamy glider.
Dragon Flight (0 min 33 sec)
Osprey Engineer is offline Find More Posts by Osprey Engineer
Latest blog entry: T-37 Dragonfly
Old Oct 23, 2013, 10:55 PM
United States, CA, Folsom
Joined Jun 2011
Watching closely....
Will add polyhedral (like in ezfly) to tame the dragon so be used as dragon trainer..
Or add a rudder and make it a crazy dragon
radhav is offline Find More Posts by radhav
Old Oct 24, 2013, 01:54 AM
baronbernie's Avatar
United States, NY, Buffalo
Joined Mar 2012
Awsome job on the design, build and paint job.
Will there be plans uploaded in the near future? My friend and I have been tearing our hair out trying to design such a dragon, although having the electric motor mounted from the back of the head.
Once again, outstanding job!
Baronbernie
baronbernie is offline Find More Posts by baronbernie
Old Oct 25, 2013, 04:01 AM
Joined Apr 2012
today my Little Red Ragon did his maiden flight, successful! Well the CoG Need some fine tuning.
The engine was first fitted with negative camber of 3 degree, lot to much,now it flies better with 0 degree, as I had on my F 22 with good results.
Video, taken form ground will be edited next time and then uploaded to YouTube, linked here.
Plans are created in Corel Draw and I will them upload here later as PDF file, as soon as they are finally checked.
First Picture from maiden attached.
Hape
Old Oct 25, 2013, 04:16 PM
Joined Apr 2012
Little Red Dragon - Plans PDF-File
after one more flight, the CoG was adjusted in the plans for a stable flight, the CG can be set about 10 mm forward or 10 mm backward, test it out.
I wrote my build log in german, and I attach it as PDF file, you can use Google Translater to read it.
The plans also are attached as PDF file, you can use both for free, for non comercial use.
Enjoy!
Hape
Old Oct 26, 2013, 12:15 AM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Danke Hape für die hervorragenden Pläne. Gut aussehende Modell!
Herzliche Grüße;
Dave-
foamdave is online now Find More Posts by foamdave
Old Oct 29, 2013, 07:02 AM
Joined Mar 2012
Great PDF plans of the dragpon. Can someone please translate the informaton given on the last page into english? Some dimensions on the plane would also be helpful.
Old Oct 29, 2013, 09:32 AM
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Love the plane... stashing away in my "gonna build someday" file.
Thanks for sharing
Just copy|paste the text your interested in into translate.google.com If it was a web page, google Chrome would translate automatically.
Not the best translation in the world, but close enough to get the gist.
rcav8r2 is offline Find More Posts by rcav8r2
Old Oct 29, 2013, 10:26 AM
Joined Apr 2012
@ baronbernie
if you download not only the plans, but also the pdf called "Baubericht" you´ll find in this pdf all informations needed, also the dimensions. The span is 900 mm, hope this will help you, to get all measured out of the plans.
And yes, use Google translator: just copy and paste the text from the "Baubericht"-PDF to Google and you get the Translation.
This Red Dragon" construction basicly is very similar to the F-22 EPP depron parkjet from Dekan, found here in the Forum:
http://www.rcgroups.com/forums/showt...+dekan&page=41
Hape
Old Oct 31, 2013, 06:17 AM
Joined Mar 2012
Thank you to all who have supplied helpful directions.
Has the maiden flight of the little red dragon been uploaded yet?
Old Oct 31, 2013, 09:41 AM
Joined Apr 2012
maiden fligth is in post production ;-)
Next days the weather forecast is very bad, rainy days, so perhaps, I´ll have the time to edit my Video in Premiere and upload it next week.
When it will be uploaded, I´ll post the YT Link here.
Hape
Here the link of the maiden Video:
Little Red Dragon maiden 2013 (4 min 25 sec)
Enjoy!
Discussion Arrow Shark Billet Outboard Dragon Drive-Brilliant Red&Jet Black newboater2013 Product Announcements 0 Jul 19, 2013 09:25 PM
Discussion red dragon 64mm edf problem!!!! Rcarl978 Foamy EDFs 0 Apr 07, 2013 07:10 PM
New Product Red Dragon 3d/pattern 9LIVES1968 Foamies (Kits) 24 Jul 03, 2008 11:49 AM
Red fly Dragon FoAmKiD Foamies (Kits) 2 May 09, 2005 12:31 AM
