Espritmodel.com Heli Air
Old Feb 25, 2013, 11:54 PM
Joined Jun 2011
Dumas 1241 1938 Triple Cockpit Barrel Back
Hi All,
Sorry to post this again but I'm reluctant to move on until I work out where I may have gone wrong here.
The sideboards are somewhat free form and the templates are to check profiles at various bulkheads. I feel like my deck is flatter than the templates would suggest yet the camber on the deck is pretty much fixed by the shape of the upper deck frames.
Have any other builders had problems in this area?
I can still sand the sideboard to what looks and feels right but I'm curious about the vertical height gap indicated by the inside edge of the template.
Cheers,
David
KiwiDavid is offline Find More Posts by KiwiDavid
Old Feb 26, 2013, 01:46 AM
oldtribefan
oldtribefan's Avatar
Walnut Creek, CA
Joined May 2007
Hi David,
When I made mine, I had enough mahogany on it to sand the sideboards to the countours (or very near) to the templates.
Kip
oldtribefan is offline Find More Posts by oldtribefan
Old Feb 26, 2013, 02:48 AM
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
David, It has been quite awile, but are the templets for after you skin it with Mahogany? If so, as Kip said, I'd just run with it. Harry
H.Lauer is offline Find More Posts by H.Lauer
Old Feb 26, 2013, 03:01 AM
Joined Jun 2011
Hi Kip,
An extra 1/16" build up would help but the templates should be right for the balsa stage rather than the finished stage. I checked back on the frame where the upper deck pieces were pressed out from and there's no way the side of the deck is high enough to end up matching the templates I have. Visually it's not going to be obvious so I will just make the most of what's there.
Cheers,
David
Old Mar 02, 2013, 08:51 PM
Ron M.
Canada, AB, Medicine Hat
Joined Sep 2011
On my 1940 barrel back the sideboards are glued up strips of mahogany 1/16" x 3/4" and it matched up fairly good when I got all the mahogany on,a little bit of planning and sanding and she's looking pretty good. Ron.
Ronkat is offline Find More Posts by Ronkat
Old Mar 03, 2013, 03:02 AM
Joined Jun 2011
Hi Ron,
3/4" sounds easier to apply than 1/8" strips. The 1938 barrel back requires tapered and beveled 1/8" strips to cover the sideboards - something I'm not looking forward to. I would have thought some very thin sheet veneer would be the way to go but I'm sure they had their reasons.
Cheers,
David
Old Mar 03, 2013, 03:25 AM
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
Hi David, Here's a pix of my ten year old Barrelback (w/cat) The 1/8 inch strips for the covering boards really wasn't that hard, just took some time. I can't see using 3/4 for this as there is a fairly radical turn, But I could be wrong.The 19' Barrelback uses solid as the triple uses 1/8" strips. If you are going to paint the covering boards black it really isn't a problem as paint hides alot. Good luck and keep us posted. Harry
Discussion Dumas 1241 1938 Triple Cockpit Barrel Back KiwiDavid Scale Boats 16 Feb 23, 2013 06:10 PM
Sold Dumas Chris Craft 1938 Triple Cockpit Barrel-Back jacktrotter Boats (FS/W) 0 Nov 12, 2012 01:12 AM
Sold Dumas Cris Craft 1938 27’ Triple cockpit barrel back kit hampboats Boats (FS/W) 1 May 07, 2012 09:44 PM
Gallery Dumas 1938 Triple Cockpit Chris-Craft Barrel Back Runabout. pfezj Scale Boats 2 Mar 16, 2010 12:07 AM
Sold 1938 Chris-Craft Triple Cockpit Barrel Back Kit #1241 CaptAhab Boats (FS/W) 0 Jul 16, 2009 01:09 AM
