Old Dec 29, 2012, 02:38 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
OS 61 needle valve O ring install
Any ideas on how this should be installed. I'm 99 sure this is the correct size but it's very, very tight and difficult to roll over the threads let alone the hump to nestle in the groove.
Thermalin is offline Find More Posts by Thermalin
Old Dec 29, 2012, 02:59 PM
DarZeelon's Avatar
Israel, Ramat HaSharon
Joined Nov 2003
Since you're obviously not the manufacturer, you don't have access to an expander that will allow this neoprene O-ring to simply fall into the groove; and you've got little choice...
Just use your fingernails to work it over the threads and then over the 'hump'.
A little oil will help.
Good luck!
DarZeelon is offline Find More Posts by DarZeelon
Old Dec 29, 2012, 06:43 PM
Thermalin's Avatar
Joined Jan 2005
True.. i can come up with something to expand it.. just wasnt sure how much expansion it would take. I guess at least enough to clear the hump plus that of the tool expanding it. I'll try some oil as well... thanks..
Old Dec 29, 2012, 08:42 PM
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Put the o-ring in some hot water for a few minutes before installing.
Bill
williame3590 is offline Find More Posts by williame3590
Old Dec 30, 2012, 05:58 PM
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
use a pin and CAREFULLY pull it over as if you were putting the tire back onto the rim of a bike with a couple of screwdrivers. im sure everybody can remember doing that
scrub monkey is offline Find More Posts by scrub monkey
Discussion ASP .61 two stroke with remote HS needle valve DYORD Engines 8 Apr 25, 2012 10:02 AM
Discussion O.S. Surpass FS-120 Needle Valve Question kpblau Engines 12 Mar 29, 2012 10:00 PM
Discussion OS 60 needle valve o-ring RC JD Engines 6 Mar 06, 2012 05:20 AM
Question What size is the O-ring for a .40 sized needle valve RCdude7478 Engines 18 Nov 18, 2011 11:12 PM
Question Source of carb needle valve o-rings wpadams Engines 4 Jan 31, 2010 05:19 PM
