Old Nov 29, 2009, 11:53 AM
Newton, Ia
Joined Nov 2007
Help!
R114F Futaba Receiver
I have an R114F Futaba receiver I want to use in a plane that requires 4 channels. I checked the futaba web site and it says a Y harness is needed if
you use all for channels. I did some research and found the adapter is used when you want use a receiver battery. Can I use the receiver without the adapeter if my ESC has a BEC and I don't use a receiver battery?
Kevin
stage1 is offline Find More Posts by stage1
Old Nov 29, 2009, 12:12 PM
Joined Aug 2002
Originally Posted by stage1 View Post
I have an R114F Futaba receiver I want to use in a plane that requires 4 channels. I checked the futaba web site and it says a Y harness is needed if you use all for channels. I did some research and found the adapter is used when you want use a receiver battery. Can I use the receiver without the adapeter if my ESC has a BEC and I don't use a receiver battery? Thanks, Kevin
Yes, the Battery Eliminator Circuit powers the RX and servos via channel 3 if using Futaba or Hitec TX or as appropriate for other compatible TX, eliminating the need for a separate battery - indeed, never plug a separate battery in when a BEC is being used.
Much more info available at
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
A.T. is offline Find More Posts by A.T.
For Sale Futaba skysport trans. Futaba R114F receiver corvairman Aircraft - General - Radio Equipment (FS/W) 0 Nov 15, 2009 07:09 PM
Sold Futaba R114F 4 Ch. Receiver - 72 mHz mustng1bob Aircraft - General - Radio Equipment (FS/W) 4 Oct 22, 2009 07:56 PM
Off Site Futaba 4 Channel R114F Micro Receiver. Cerbia Aircraft - General - Radio Equipment (FS/W) 3 Sep 09, 2009 03:24 PM
Question Futaba R114F Receiver r/cdawg Radios 1 Feb 22, 2004 11:16 PM
Futaba R114F receiver Tony Oliver Dock Talk 4 Jan 17, 2004 09:03 AM
