Old Jun 21, 2014, 09:12 AM
mhalpha is offline
Find More Posts by mhalpha
Cleveland, OH
Joined Mar 2003
Eagle Tree Camera Gimbal setup?
I recently purchased an Eagle Tree Vector FC + OSD system to replace my XAircraft FC1212-S + AHRS-S controller. I use a TurboAce Z8 3-axis camera gimbal mount on my quad. I was able to use the built-in tilt/roll functions of the XAircraft controller, to control the gimbal on my quad, keeping the camera gimbal level at any attitude. I don't see anywhere in the Vector manual or online forums how I can do the same functions with the Vector setup. Will the Vector be able to control my articulating gimbal to keep it centered through different attitudes? If so, where do I plug in the gimbal servo leads to make this happen?
mhalpha is offline Find More Posts by mhalpha
Old Jun 22, 2014, 07:44 AM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
No, it won't be able to do this.
There are lots of good 3rd party gimbal controllers out there, better to use one of those.
Geoff
garris2 is offline Find More Posts by garris2
Old Oct 30, 2014, 04:32 PM
sgali is offline
Find More Posts by sgali
Joined Sep 2014
3rd party gimbal controller for ET Vector
Geoff
Hmmm, as a noob and coming from APM, I had to learn the costly way that there are as many protocols as manufacturers (and luckily open source solutions for tinkerers) to get telemetry, LEDs and gimbals working.
So, please save me some dough and time and sweat to make the right choice when it comes to buy a 3rd party gimbal control that actually works without too much hassle (some is expected and welcome ) to set up a 2D brushless gimbal control on a Eagle Tree Vector.
I do know how to query google, but maybe I am just too stupid to pick the right results to find what I am looking for - as I have not found anything meaningful yet. Plus, and a big minus for Eagle Tree's manual, searching for gimbal returns ZERO results, despite their Vector being advertised as the state-of-the-art FPV solution....(doesn't that include a gimbal control??? Am I missing something???)
Any hints towards a sound buying choice is much appreciated!
Cheers
Sgali
sgali is offline Find More Posts by sgali
Last edited by sgali; Oct 30, 2014 at 04:46 PM. Reason: Important requirement missing
Old Oct 31, 2014, 08:02 AM
JohnET is offline
Find More Posts by JohnET
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Hello,
The Vector does not have gimbal control. Most brushless gimbals have their own controllers and therefore will not need any input from the flight controller. If you are using a non-brushless gimbal (servo controlled), you will need a separate controller as well. If you need to pan or tilt your gimbal, the connections should go directly to your RX.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old May 15, 2015, 01:32 AM
Don 2416n is offline
Find More Posts by Don 2416n
San Diego
Joined Feb 2003
What if we're using ppm? I thought only 1 wire is used from the rcvr to the FC. Doesn't this negate the use of the other channels?
Don 2416n is offline Find More Posts by Don 2416n
Old May 15, 2015, 05:47 AM
boceifo is offline
Find More Posts by boceifo
United States, MO, Ozark
Joined Apr 2014
Depends. I have a frsky x8r setup to use 1-8 on s-bus and 9-16 on regular servo outputs on mine works great for controlling my tarot gimbal.
boceifo is offline Find More Posts by boceifo
Old May 15, 2015, 01:30 PM
stxShadow is offline
Find More Posts by stxShadow
Germany, NRW, GŁtersloh
Joined Feb 2015
Works for JETI Remote Controls and EZUHF too .....
stxShadow is offline Find More Posts by stxShadow
Old May 15, 2015, 11:50 PM
San Diego
Joined Feb 2003
I'm using ppm but thought I read that you can't run the 8 channel scheme even though the rcvr is 8 channel due to the data won't support it in ppm mode.
I just want to be able to adjust the pitch of the gimbal. I'm thinking on channel 7.
Old May 16, 2015, 05:27 AM
boceifo is offline
Joined Apr 2014
What type of TX and RX are you using
Old May 16, 2015, 08:26 AM
San Diego
Joined Feb 2003
Turnigy 9xr and frsky d8r-xp
Old May 16, 2015, 10:20 AM
boceifo is offline
Joined Apr 2014
I don't think that will be possible with that receiver. I know for certain that it works on the frsky x8r. But the one you have, I don't belive will be able to do that.
Old Jun 04, 2015, 01:54 AM
San Diego
Joined Feb 2003
Looking through my junk box I found a brand new X8R. I may try setting it up.
Thanks for the info.
For Sale Eagle tree PRO// OSD - FDR PRO full setup LoudLoo33 FPV Equipment (FS/W) 1 Oct 27, 2013 12:16 PM
For Sale Full Eagle Tree OSD Setup **Price Reduced** RCManiacPHCB13 FPV Equipment (FS/W) 1 Oct 09, 2013 08:15 PM
For Sale Full Eagle Tree OSD Setup RCManiacPHCB13 FPV Equipment (FS/W) 0 Sep 30, 2013 09:50 PM
Sold Eagle Tree Setup flyhigh300 FPV Equipment (FS/W) 2 Sep 24, 2013 11:01 AM
Sold Eagle Tree - Setups flyhigh300 FPV Equipment (FS/W) 1 Sep 23, 2013 02:17 PM
