Old Jan 20, 2014, 01:07 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Mini-HowTo
OLRB: Open Long Range Beacon -low cost tracker
by long range i mean over 25 miles and by low cost i mean less than a dollar in parts. this was inspired by my great success receiving signals at over 2000km distance from srnets low power ham satellite beacon(http://www.rcgroups.com/forums/showthread.php?t=2040936). it uses similar power and uhf frequencies so the potential is amazing. when i mentioned this in my 1gram gps thread several people asked for diy info so here we are.
basically it uses one of those cheap 50 cent ebay ook transmitter modules converted to fm and 50 cent tiny13 mcu programmed to generate the beacon signal. the rx that comes with the module is very short range but a low cost fm walkie talkie (also ebay) can provide los range of many miles. converting the tx to fm takes only a minute and a few pennies in parts (2 caps, 1 resistor). below is a photo showing one of the units with piano wire antenna. also attached is a google screenshot showing distance achieved using that same module. but in this case with yagi arrays (also easy to build for pennies). other photos included show the walke talkie and yagi. sample sound file, schematic, and arduino demo source code for the t13 too.
if you have questions or want more info or photos dont hesitate to ask.
01/28/2014
ive added a photo with gps attached using tone generation capability to send battery voltage and gps lat/lon via morse. also sound sample of that from 9 miles. its not the clearest in the world but pretty good considering, unlike the 75 mile wilderness contact, it was urban environment. plenty good enough to locate a plane as long as you or a bud know the code. its not necessary to learn all the characters but just numbers which is a lot easier. in fact by recording it with your phone or camera like i did you dont even have to know the code. just hit pause after each digit and look up in the chart. heres a snip from the morse program which might help with that. or give a head start to anybody who wants to develop their own version of the program.
Code:
.db 0b00000101,0b10000101,0b11000101,0b11100101,0b11110101,0b11111101
;     ----- '0'  .---- '1'  ..--- '2'  ...-- '3'  ....- '4'  ..... '5'
.db 0b01111101,0b00111101,0b00011101,0b00001101
;     -.... '6'  --... '7'  ---.. '8'  ----. '9'
even if you dont interpret the morse data just hearing the tones can be very useful locating a lost model with the right antenna. really the antenna doesnt even have to be that fancy. just stock rubber duckie and blocking the signal with your body like fmkit taught us will allow you to home in.
2/3/2014
heres a link to the "50 cent" ook modules we are talking about. note that they normally come in rx/tx pairs for a dollar. even cheaper on alibaba. with some prodding you can get them to sell 2 transmitters instead of one each. of course as usual this is hard to do if you just buy one, so loosen up those purse strings. i never understood people who buy just one of anything. specially things that only cost a buck and take a month to ship like mcus and parts that are easy to fry. what are these guys thinking?
http://www.ebay.com/itm/433Mhz-RF-tr...item2a35eb6201
i went into this further up in the thread but maybe good idea to repeat it here.
2/12/2014
schematic, source, and hex for t13 version 0.4 attached. power control has been added to the original circuit. note that b0 is the power control pin (active high) and beep is b2. use fush=ed fusl=3a so the chip runs it at 9.6mhz instead of factory default which causes 1/8th speed.
3/19/2014
btw recent discussion of morse decoders motivated me to dig up and old project and sure enough i was able to convert the sound sample here into readout on lcd. heres a photo of a version that shows the converted morse audio and above it current position from attached gps. couple characters lower left tell you if you are getting closer or farther away and point north, south, east, or west. naturally a compass in your hand is very useful.
photos:
dave1993 is offline Find More Posts by dave1993
Old Jan 20, 2014, 01:15 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
hmmm... im already getting questions about using frs handheld which i guess is more common. i have managed that approach with similar range too but instead of the cheapo ook modules it was necessary to use popular rfm22b which costs couple bucks more. if still interested maybe i can put up some info on that. let me know.
Old Jan 20, 2014, 02:15 PM
irun4fundotca is offline
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
any chance you can color the components that you added to the schematic?
irun4fundotca is offline Find More Posts by irun4fundotca
Old Jan 20, 2014, 02:35 PM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Very good work indeed.
FRS walkie talkies may well be more common, and cheap, but if they dont work at the same frequency as the radio transmitter modules, they wont work.
srnet is offline Find More Posts by srnet
Old Jan 20, 2014, 03:44 PM
Flying Wood For Fun
Joined Jan 2012
Heres the standard list of FRS channels
Channel........Frequency (MHz)......Notes
1 ..................462.5625..... Shared with GMRS
2.................. 462.5875..... Shared with GMRS
3.................. 462.6125..... Shared with GMRS
4.................. 462.6375..... Shared with GMRS
5.................. 462.6625..... Shared with GMRS
6.................. 462.6875..... Shared with GMRS
7.................. 462.7125..... Shared with GMRS
8.................. 467.5625..... FRS use only
9.................. 467.5875..... FRS use only
10................ 467.6125..... FRS use only
11................ 467.6375..... FRS use only
12................ 467.6625..... FRS use only
13................ 467.6875..... FRS use only
14................ 467.7125..... FRS use only
Old Jan 20, 2014, 04:38 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
Cool idea. Could you detail the mods to the module for FM operation? I've got one of those OOK module sets collecting dust and a 70cm HT. Might be a fun little project.
ttabbal is offline Find More Posts by ttabbal
Old Jan 21, 2014, 01:56 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
You mean such combo ?
http://www.ebay.com/itm/433MHz-Trans...-/190949200438
An improvement idea: the Tx could be powered from a lost plane circuit, thus transmitting only when needed
renatoa is offline Find More Posts by renatoa
Old Jan 21, 2014, 06:08 AM
Flying Wood For Fun
Joined Jan 2012
this is the one I ordered and they ended up sending two sets
http://www.ebay.com/itm/181210718587
Old Jan 21, 2014, 04:28 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
your wish is my command. i attached a new schematic to post #1 showing components required for fm conversion circled in red.
Old Jan 21, 2014, 04:33 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
hi stuart, thanks for the complement. but as far as frs, not quite true:
as indicated in the table irun posted these frequencies no problem for the rfm22b. as you know its quite easy to accomplish when programmed in direct mode.
Old Jan 21, 2014, 08:56 PM
Flying Wood For Fun
Joined Jan 2012
I hate to ask, any chance on a macro pic of the side the components are added to?
Old Jan 21, 2014, 11:42 PM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
I realise that, my comment was really about the cheap OOK style modules.
There are real cheap, $1-$2, but will likely only be available for the 433/434Mhz region, and not where the LRS sets operate.
Old Jan 22, 2014, 12:39 AM
Flying Wood For Fun
Joined Jan 2012
well you can always add a tunable pot to it
in a smaller way of course, the above photo isn't the smallest solution
Old Jan 22, 2014, 12:45 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
The 'tuneable pot' is probably there to fine tune the modules so that they are closer together in frequency for better performance.
If the pot was capable of changing the module from 433Mhz up to 466Mhz, the adjustment would be so unstable you might never hear the beacon on the walkie talkie.
Old Jan 22, 2014, 12:57 AM
Flying Wood For Fun
Joined Jan 2012
ahh ok that makes sence
Cool EagleLink: Integrated long range, low cost, 12 ch RC/Video FPV transceiver system billpa FPV Talk 605 Nov 19, 2013 08:01 PM
Discussion Locator beacon - with very long range capability srnet FPV Talk 0 Jul 30, 2013 10:59 AM
Wanted low cost antenna tracker system iosxphone Aircraft - General - Radio Equipment (FS/W) 0 Nov 21, 2010 04:33 AM
Help! low cost light laser range finder? swshouse UAV - Unmanned Aerial Vehicles 28 Sep 21, 2009 06:17 AM
Discussion Is there a low cost Futaba Rx that are full range and single conversion? arukum17 Radios 6 Jun 01, 2006 01:32 PM
