Old Jun 29, 2012, 05:44 PM
AKPilot is offline
Find More Posts by AKPilot
St. Louis, MO
Joined Aug 2008
Pico Motor Mount
I've searched high and low and can't seem to find what I'm looking for. I want to use an E-flite motor on my Pico
Does anyone know where I can find a motor mount for the Pico Slow Stick, so I can use an E-flite motor on it?
Or, any suggestions on how to modify an existing mm to fit a Pico stick?
AKPilot is offline Find More Posts by AKPilot
Old Jun 29, 2012, 09:30 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
You'd have to refer the size of your E-flite motor to the mounts, and Pico Stick's boom as well. The boom is quite thin one, so it's easy to add something for fitting any given mount. ie. GWS 20mm or 28mm ones. http://www.caliberhobby.com/motors_mounts.html
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jun 30, 2012, 07:31 AM
AKPilot is offline
St. Louis, MO
Joined Aug 2008
Thanks for the suggestion Chen, but both the GWS ones (if not already discontinued) and the E-flite 1915 & 1916s are made for the full-size slow stick (10mm) - not the Pico version.
I was just hoping that someone has come across something specifically made for the Pico Slow Stick as far as a mount.
Anyone? Anyone?
Old Jun 30, 2012, 08:10 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
If I recall it correctly that the boom of Pico Stick is 7.7 x 5mm, while the mentioned mounts are all 10mm square ones, probably the easiest way would be glueing some pieces of balsa pieces or even the coffee stirs to the boom to make it fitting the 10mm hole of the mounts.
I'm afraid that it's hard to find out any mounts fitting the 7.7 x 5mm boom. Just my two cents.
Chen
Old Apr 21, 2014, 07:56 PM
daniirwan is offline
Find More Posts by daniirwan
Freezes when panicking
daniirwan's Avatar
Kuala Lumpur, Malaysia
Joined Mar 2007
AKPilot, I'm in the same boat as you. But instead of an eflite motor, I'm looking to use a generic brushless outrunner motor. So any luck on your end?
daniirwan is offline Find More Posts by daniirwan
For Sale Zenoah Gas Motor Engine Mount and Rubber Motor Mounts for your gas boat Rondog Boats (FS/W) 0 Jun 17, 2012 10:19 PM
Wanted Motor Mounts for turnigy motors thewz Aircraft - Electric - Power Systems (FS/W) 2 Jun 17, 2012 09:38 AM
Sold 10gr Motor & ESC and Pico Flight Pack strouse Aircraft - Electric - Airplanes (FS/W) 4 May 23, 2012 07:25 AM
Help! multiplex pico cub brushless motor mount Q ? lud Foamies (Kits) 6 Feb 23, 2012 06:33 PM
Mounting Motor in Pico Jet Combat sgil2001 Foamies (Kits) 5 Oct 31, 2001 02:21 AM
