Old Mar 08, 2015, 06:37 PM
shonmac is online now
Find More Posts by shonmac
shonmac's Avatar
United States, NJ, Dunellen
Joined Aug 2014
Originally Posted by TechJunkieRC View Post
That nose gear looks great. Did you have to mod it much to get it to fit? I love my SR but the nose gear not so much! It is one of the weak spots IMHO. I even created a supporting bracket for mine. It has helped it to hold up so far but I can definitely tell that the nose gear would be gone if it wasn't for the support I made.
I really like the looks of your mod and would consider it if it works well for you!
Well unfortunately I can not find the control arm for the nose gear I had to use it as a fixed nose gear without the ability to steer. I am sure I did not throe it away because I never throw airplane stuff away . Even if its mangled foam I find a reason to hold on to it for a week. Maybe I should check my 2 year old's room and toy chest.
Good news is that as a fixed gear and some foam behind it so it does not travel; it has held up well. I am going to look around for suitable replacement nose gear.
I will post on the subject if I find something thst can be used. And I hope you post if you find something as well because just simply replacing it with the original part seems unlikely. I cant find the original part anywhere.
shonmac is online now Find More Posts by shonmac
Old Mar 08, 2015, 10:07 PM
TechJunkieRC is offline
Find More Posts by TechJunkieRC
Gone Flying
TechJunkieRC's Avatar
United States, IN, Covington
Joined Dec 2012
I was able to fly my SR today and it was truly enjoyable. My front gear is still OK but I would like something that I don't have to worry about. I check it before and after every flight. The bracket I made to stabilize it has done it's job but I know at some point I will want to change it.
I look forward to seeing what you come up with!
TechJunkieRC is offline Find More Posts by TechJunkieRC
Old Apr 04, 2015, 01:50 PM
rcflyinff is offline
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Would somebody mind telling me where the top battery hatch mod is in this thread. I did a quick search, but was unable to find it. Thank you and Happy Easter.
rcflyinff is offline Find More Posts by rcflyinff
Old Apr 08, 2015, 03:04 AM
agedflier is offline
Find More Posts by agedflier
Australia, VIC, Bendigo
Joined Jan 2012
It's not a TOP hatch.it's a mod for laying the battery flat and works well .I did it...It is in Eric Henderson's post on page 42 Post 618. Hope that's what you were referring to...
agedflier is offline Find More Posts by agedflier
Old Apr 08, 2015, 06:26 AM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Thank you agedflier. I must have been mistaken. I thought there was a mod similar to the Grand Cruiser one. May try this.
Old Apr 08, 2015, 05:24 PM
Joined Jan 2012
I like it too..I might go have another look at mine...I think there might be a problem as the engine cowl on the SR22 is separate whereas the Grand Cruiser is part of the fuselage.(no propeller)
Discussion telemaster sr ARF jrplane Electric Plane Talk 1 Nov 27, 2010 09:43 PM
Discussion Dynam Sky Trainer 4CH RTF NJRC Beginner Training Area (Aircraft-Electric) 10 Nov 18, 2010 08:45 PM
For Sale Aero Sprint Elec. ARF Trainer 50" W/S puplover Aircraft - Electric - Airplanes (FS/W) 0 Nov 15, 2010 04:15 PM
Sold Aero Sprint ARF trainer by Parma puplover Aircraft - Fuel - Airplanes (FS/W) 0 Nov 13, 2010 02:47 PM
For Sale MM Special High-Wing Trainer ARF Kit AJ750 Aircraft - Electric - Airplanes (FS/W) 4 Oct 29, 2010 10:36 PM
