Old Sep 17, 2014, 01:54 PM
Los Angeles, CA
Joined Mar 2004
How to cut design on colored packing tape
I'd like to use colored packing tape on my depron built planes.
How do you cut a simple design on it before applying to the plane?
Any suggestions welcome! Thanks
lv2soar is offline Find More Posts by lv2soar
Old Sep 17, 2014, 02:16 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Lay the tape out on a piece of glass, cut the design then lift the tape from the glass and apply to the model.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Sep 17, 2014, 03:41 PM
Los Angeles, CA
Joined Mar 2004
Larry
Hi Larry
Will the sticky adhesive comes off after sticking to the glass?
Old Sep 17, 2014, 07:02 PM
Brazil, SP, Itu
Joined Mar 2008
If you aply windex on the glass it will be much more easy to take out the tape after cut, sorry for the bad english.
LUIZ PACHECO is offline Find More Posts by LUIZ PACHECO
Old Sep 17, 2014, 07:31 PM
CrashnBurn420's Avatar
Joined Dec 2012
I put a few strips of heavy clear packing tape onto my glass work area first. then layed the colored tape on top of that, cut the pattern and it peeled up pretty easy. Straight onto the glass the tape wasn't strong enough to peel back up.Name: uploadfromtaptalk1411000307359.jpg
Description:
CrashnBurn420 is online now Find More Posts by CrashnBurn420
Old Sep 18, 2014, 06:38 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
+1, and your english is better than a lot of native speakers.
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 18, 2014, 10:16 AM
rajazo's Avatar
Chile
Joined Jul 2010
I use wax paper on more detailed stickers like numbers or letters
rajazo is online now Find More Posts by rajazo
Old Sep 18, 2014, 12:15 PM
AKA Don
bz1mcr's Avatar
United States, MI, Houghton Lake
Joined Dec 2002
I have put the tape sticky side down on my cutting mat. Stays in place, blade stays sharp, and comes off with no problem. Keep the designs simple though, I suspect narrow areas less than 3 or 4 mm wide could be a problem if between wider sections.
bz1mcr is offline Find More Posts by bz1mcr
Old Sep 18, 2014, 01:25 PM
Blacksburg, VA 24060 USA
Joined Feb 2000
What brand of colored vinyl tape are folks using these days? Tape Brothers?
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Sep 18, 2014, 01:38 PM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I have some plastic from a Lowdepot kinda place and one side has a slight texture.
It's great as a base for tape cutting because it comes off much more easily.
Not sure if it's an ethylene or PVC but both types are easy on knife tips.
PS
when you buy TAPE make sure the COLOR is on the adhesive side not the 1st surface.
Usually the harder to find colors are the culprits.
Bob
Hoosier Cutout Service
birdofplay is offline Find More Posts by birdofplay
Old Sep 18, 2014, 04:50 PM
AKA Don
bz1mcr's Avatar
Joined Dec 2002
Jim R.
I don't think most "packing tape" is Vinyl. I think, most electrical tape is vinly. It is much heavier and far more stretchy. Also the color of vinyl tape is opaque, that's why it makes good signs.
Most packaging supply houses have "packing tape" available in colors. As others said the tape is actually clear and the adhesive is colored. That give it a nice deep shiny appearance like a clear coat car finish. Packing tape is often available in different thicknesses, but all the colored I have is what I would call thin tape. It is rather light weight but not fully opaque. That means overlaps will show and overlaps of different colors have a neat blend color.
Old Sep 19, 2014, 10:26 AM
Joined Feb 2000
Has anyone bought from Tape Brothers?
Jim R.
Old Sep 19, 2014, 01:31 PM
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Many have.
I buy from this place:
http://www.fast-pack.com/colored_tape.html
very thin, very light weight, I lay it on wax paper and very gingerly peel it after cutting to shape. For any real complexity or small logos I'd use electrical tape.
BrownEyedFool is online now Find More Posts by BrownEyedFool
Old Sep 21, 2014, 07:34 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by BrownEyedFool View Post
Many have.
Best tape by far!
Light weight
Super sticky adhesive
Lasts a long time.
This one is 5 years old. Tape cut on glass. (The stars are decals.)
hoppy is offline Find More Posts by hoppy
Discussion Color packing tape flyinginaz28 Foamies (Scratchbuilt) 15 Apr 17, 2014 03:07 AM
Discussion Using colored packing tape over painted EPO? Zangetsu57 Foamies (Kits) 1 Jan 27, 2014 10:37 AM
Sold flat foamie colored tape and 5 rolls of hinge tape bigchuck09 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 03, 2013 04:52 PM
Discussion How to: Cut a roll of packing tape in half trees The Builders Workshop 12 Apr 25, 2010 11:06 AM
How Can I Cut Colored Tape In Long Pieces? hoppy Power Systems 6 Jun 01, 2001 10:08 AM
